Degree'n a cam parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2013, 11:34 PM
Banned
Hello..
So I have the comp cams degree kit, used it many times, with flat tappet cams, easy just bought a single solid lifter and good to go..
well this engine that I'll be stab'n a cam in is a g.m. hyd roller..
as we all know roller lifters tend to be costly, so..
could one, get a used roller and tac the lifter pushrod seat to the outer body and use that as the solid lifter..
or would it be better to take the hyd lifter apart and lock the plunger somehow???
I'm thinking a few zaps with the mig. would do it..
ofcource I'll need a lifter thats not trashed,,
sound like a plan, or sound more like fail..
Old 05-11-2013, 06:08 AM
GMC boogie's Avatar
Heads on or off?
Old 05-11-2013, 07:49 AM
Banned
Originally Posted by GMC boogie View Post
Heads on or off?
on......,/
Old 05-11-2013, 09:33 AM
GMC boogie's Avatar
With the heads off, I use a mag base/dial indicator mounted on the deck with a rod mounted on the rim of the lifter I will be using.
In your case, some checking springs should work or you could disassemble a spare lifter and modify it to make it solid.
why degree a cam with new parts allan b Engine 3 05-08-2012 01:52 PM
Cam degree mikey0oo Engine 0 04-04-2011 04:53 PM
cam degree zoomo Engine 15 09-02-2010 08:09 PM
to degree a cam? sam_bo3 Engine 4 11-13-2009 09:11 PM
Degree that cam kseay Engine 10 05-02-2005 06:26 PM
