We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-03-2009, 12:57 PM
Old Pony's Avatar
Old Pony Old Pony is offline
Dieseling, oil spewing 347
Big trouble guys...
I've got a relatively new 347 stroker... lately it's been dieseling to the point that it blows the passenger side valve cover gasket spewing oil everywhere!! The idle is about right and the timing is at 12 degrees. Seems to run fine until I shut it off. Any ideas?
Thanks!!
Old 07-03-2009, 01:03 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
I would check and make sure the balancer hasn`t spun as it sure sounds like the timing is off. It also could be the fuel mixture is excessively rich which has caused carbon build up. Need more build info such as the compression ratio, intended usage, etc.
Old 07-03-2009, 01:06 PM
Old Pony's Avatar
Street use...10.5 to 1 Edelbrock 800, Performer RPM manifold, Trick Flow heads.
Old 07-03-2009, 01:24 PM
Old Pony's Avatar
Takin' the balancer off as we speak... thanks for the idea!!!
Old 07-03-2009, 01:47 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
GM added an anti-dieseling solenoid to the carburetor linkage on early 70's cars when car makers were forced to lower compression ratios and run the motors hotter to meet Federal emissions laws due to the Arab Oil Embargo and pressure from "green" people. The idea is to close the throttle blades completely when the ignition is killed, so that no fuel/air can enter the motor, therefore no dieseling is possible. When the ignition is re-activated, the solenoid pushes the throttle blades to the idle position and all is good. A google search for "anti-dieseling solenoid" will yield sources for the solenoid and bracketry to mount it.
Old 07-03-2009, 02:24 PM
Old Pony's Avatar
Thanks, but it ran fine before... it's not a stock motor anyway, but thanks!!
Old 07-03-2009, 02:27 PM
Senior Curmudgeon
Wiki editor
Wiki Edits: 210
Old 07-03-2009, 02:59 PM
800 cfm is way too big for 347 cubic inches. A 650 or 700 would have served you better. The compression ratio is also on the high side. With that much compression plus too big a carb it`s quite possible you have a carbon build up issue. I would run some water out of a bottle into the carb while giving it throttle or run it low on gas and pour in a can of seafoam, wait 15 minutes then do some wide open throttle blasts.
Old 07-03-2009, 03:40 PM
Old Pony's Avatar
I thought it was big too, but the techs at Edelbrock said that's what I need... anything over 400HP they said to use the 800. They said it draws differently than Holley. If I went with a Holley a 600 or 750 would be appropriate. Took out the plugs and they looked fine... took off the balancer, and it's it's not spun, took off the distributer, the gear is fine... I'm stumped!!
Old 07-03-2009, 05:24 PM
cobalt327's Avatar
WFO
cobalt327's barnstar
Wiki editor
Last wiki edit: Chevrolet restoration packets
Wiki Edits: 20
Check the mechanical advance- clean it real good and be sure it's free to move- it sounds like it's sticking advanced.
Be sure the inside of the cap isn't carbon tracked or cracked. Check in the dark under the hood for ignition wires cross firing. Are the plugs' heat range too hot?
Does the engine diesel every time, or sometimes?
Does temporarily retarding the ignition have any effect?
Old 07-03-2009, 06:05 PM
Old Pony's Avatar
Brand new wires, new distributer (HEI), using the recommended plugs, retarding helped a little, still diesels, but at least it's not real bad... I'm stumped... like the other guy said, it's a big carb (800), but that's what Edelbrock recommended. I've got a 650 laying around... maybe I'll try that tomorrow. Seems like it's running rich though (really smoked up the garage), but the mixture is lean... put a vacuum gage on it, leaned it out till vacuum drop, then richened it up a quarter turn or so. It's basically a brand new engine, so it's not carboned up I don't think. It runs REAL hot when it's not moving also. I'm still stumped!!
Old 07-03-2009, 09:17 PM
cobalt327's Avatar
WFO
Wiki editor
Wiki Edits: 20
Brand new or not- check that the centrifugal advance is freely operating, that there's no way it can hang up at all.
If you start it up cold and immediately cut the engine- no warm up- does it diesel? Or does it need to run for a while (how long?) before it diesels when shut off?
I'm wondering if there's a hot-spot that's formed in a combustion chamber. Might be a good time to throw a can of your favorite combustion chamber cleaner at it. People say Seafoam is good...
Also, despite the plugs being the recommended ones, the fuel blends have just changed around the nation- so there can be a fuel related issue that didn't exist just weeks ago. Something to consider.
Another thing to try, is to completely back off the curb idle screw until the blades are shut tightly. Start the engine (with it in whatever condition that it needs to be in to diesel- warmed up, whatever) and let fully off the gas and turn off the key. This mimics the way an anti-dieseling solenoid works, w/o having to actually install one. Does this help or does it still diesel?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Deisling, oil spewing 347"
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Oil Priming - Chevy V8 - No Oil to Lifter Bores - Help leejoy Engine 4 03-09-2008 10:55 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
Excessive oil under valve covers in SBC? TVR383 Engine 13 11-21-2005 12:48 AM
347 Oil filter MeligN Engine 5 11-24-2004 10:50 PM
