Is this delay from park to drive a big problem on TH350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2004, 03:42 PM
I just bought a 68 Camaro with a long tail TH350 in it I put a B&M shift improver kit in it and now when you go from park to either reverse or drive it takes it a couple of seconds to enguage is this bad news for things to come?
Old 08-02-2004, 04:27 PM
Frisco's Avatar
Glad To Be Here
You do have a problem.
Here are a few things for you to check.
Fluid level.
Middle plate, transfer plate or support plate improperly installed.
Valve body bolts loose.
These suggestions are from the B&M instructions.
Hopefully, our board expert CROSLEY will see your question and respond.
