Hotrodders Bulletin Board
#1
Delco Radio Speakers
The older Delco radios need 10 ohm speakers. I'm advised that installation of speakers with less ohms cause the radio to see the speakers as a short and damage the radio. At some point they apparently changed to speakers with lesser ohms.
Does anyone know when this occurred? I'm having a problem with my 80s vintage El Camino. I keep "losing" radios and I'm wondering if I should have speakers with more ohms. |
#2
re: Delco Radio Speakers
From what I remember of those radios, the standard speakers used to be 8 ohms. Later ones have switched to 4 ohms.
Using a 4 ohm speaker may cause problems with overdriving the power amp at high volume, but its not equivalent to a short circuit. Do you run at really high volume levels with your vintage radio? One simple solution to protect the radio is to add another 4 ohm speaker in series with the ones you have. If the current ones are dash or in-door speakers, add a second set in series up under the dash pointed down. Two 4 ohm speakers in series (positive of one speaker connected to negative of the other) will get you 8 ohms. It would be probably best for sound quality if the two speakers are matched in size and type. Bruce |
#3
The problem is occurring in my '86 El Camino.
I've "lost" two radios now. I replaced the two original dash speakers with some cheapies from Walmart. I couldn't justify big dollar speakers for an occasional driver that usually only plays oldies. I'm not a high volume listener so it wouldn't appear to be from that. My thought was maybe the speakers were causing the problem. |
Back to top |
Similar Threads for: "Delco Radio Speakers"
| Do NOT buy AC Delco Duraguard Oil Filters!!! | indy_85stariones | Engine | 73 | 09-15-2008 10:04 AM |
| Old radio personalities and some help | Halloweenking | Hotrodders' Lounge | 17 | 06-04-2007 12:49 AM |
| determining positive from ground | MeligN | Electrical | 13 | 02-09-2006 10:40 PM |
| 70's Delco Radio | HiPoVAN | Electrical | 3 | 02-17-2004 06:55 AM |
| Radio Station Update | Halloweenking | Hotrodders' Lounge | 8 | 07-28-2002 10:54 PM |
