Delco Remy Alternator question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 08:27 PM
kleen56's Avatar
A buddy of mine gave me an alternator he had in his garage. The numbers on it are 1102491 37A 6G20 12v Neg. I'm guessing it's a 37 Amp alternator. I also found they are obsolete and replaced by another model number. My question is.. is this alternator a self starting or does it require a regulator? It has the BAT terminal and GND and also terminal 1 and 2 like other GM alternators I've seen. Before I install this thing I want be sure it'll work. Thanks guys.
Old 04-21-2013, 08:47 PM
Faith - Respect - Trust
Just a thought, 37A is a low amp altenator, why not get something like an 85 or 100 amp with the regulator built in...they have really come down in price. I bought a chrome one a number of years ago for under $100 on sale...still works great...still around that price and if you shop, probably cheaper.
Not sure if you need a regulator on that one but with the number of outlets, I wouldn't be surprised, you could pop the cover and see if it has a diode trio...then you know what you got.
Old 04-22-2013, 03:35 AM
EOD Guy's Avatar
If terminals 1-2 are coming out the rear, vs the side, you most prob have an external regulated alt.
Old 04-22-2013, 08:52 AM
The 37 amp alternators are mostly external regulation. I'm not aware of many 10/12 SI family alternators with that low an output. Wrecking yard 12 SI alternators with 78 amp output are $15 all day long - you'll spend more than that wiring up an external regulator.
Old 04-22-2013, 10:18 AM
kleen56's Avatar
I appreciate the info guys. The reason I was interested in using this alternator is because the casing is polished and has billet pulleys. I've removed the pulleys and fan blade and I can reuse them on another alternator. I'm running a 10SI alternator on my Ford truck now using the 1 wire setup. The alternator I have is a 10SI, however the field plugs are on the side of the casing and not out the back as mentioned by another poster. The casing on this alternator is different so I can't interchange that. I thought 37 amps was low as well. Must be an older model alternator? I got the information from the casing numbers but I'm also wondering if someone who went through all the trouble to put nice custom parts on it, didn't go through and upgrade the insides? I may have to pull it apart! Is there a way of checking the actual amperage without installing it ?
Old 04-22-2013, 04:02 PM
EOD Guy's Avatar
Might get a reading from the parts store for free...... not sure if their setup is go or no-go etc....
Delco Remy alternator gowser Electrical 6 02-19-2012 05:19 PM
Delco Remy CS130D Alternator Rebuild Torque454 Electrical 12 04-14-2011 10:51 AM
DELCO/REMY alternator wiring/fordI Christine 64 Electrical 3 07-17-2006 03:43 PM
Delco Remy Starter Mugfors Electrical 2 07-13-2005 12:08 PM
1949 DELCO-REMY Electrical Equipment Handbook ONLINE khardy Electrical 0 04-24-2004 10:45 PM
