Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Demolition derby
Old 12-24-2012, 01:23 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Originally Posted by vinniekq2 View Post
If the pay our makes it worth while to build an engine?
I would think a worn out engine or"clearanced" engine would be good.Instead of buying a stroker crank,I think I would buy a set of gears and weld the spiders.I dont see the advantage of a stroker?
Yep you will never reach more than 20 mph anyway unless your doing some crazy figure 8 style dirby but i think everybody stopped that back in the 70s.
Might want to use seperate trans cooler and not run the trans thru the rad since its a target. Dont forget to weld a backup linkage to the trans and run a lever up thru the floor. Also make sure she will start in gear.
Aumuseal is great for a sealing leaky radiators. I would toss some in there just in case it might help.
