Jet sizes can be up sized with a drill bit.There used to be special bits sold for that purpose.trouble with drilling is the machine marks left in the hole were not consistent enough to meter fuel flow,or sometimes the increase was huge in comparison to the size difference due to rifling in the hole.
some people drilled the jets from both ends to prevent rifling.or buy jets that are broached,,, Thanks tech for the use of your vocabulary |
You are a total jerkoff of the highest order and you have no business even posting 90% of the time- you have no engine experience all you are is a ****ing book worm. Last edited by cobalt327; 12-14-2012 at 11:26 PM. |
same reason.. why water spray farthar when you put your finger over hose end... the pressure didn't change.. just the size of the hole.. why does ehaust speed slow when it gets to the collector... Last edited by gearheadslife; 12-15-2012 at 06:26 AM. |
Jets varying in flow rate such that jets with two numbers apart may flow the same, ie a 70 jet that flows on the high end of the tolerance may flow the same as a 72 jet that flows on the low side of the tolerance. You can buy sets of flow tested jets but they cost alot more.
The flow through a jet is determined by the surface finish, the length of the orifice, the entrance and exit angles and their finish, and the size of the orifice. When a jet is drilled oversize, all of these things are changed except the angles of exit/entrance, but even the lengths of the angles are changed.
The number stamped on a jet (Rochester, Holley, etc.) is an indication of the actual flow, NOT the orifice diameter. The manufacturers flow the jets to see what number they get stamped on them. The same orifice diameter jet may be stamped w/different numbers. This tells you they do not flow the same, even though the orifice diameter is the same. Subtle differences in the above parameters account for the different flows. The difference between the correct and too rich/lean jet sizes may only be 0.002”-0.004”. There are no readily available drill bits that are that close in size to one another. So at best, the changes made to jets by hand drilling are going to be in steps decided by the availability of drill bits. Because drill bits are often available in 1/64” increments (the small numbered bits- which have a finer increment between bits- are too small for drilling the average carb metering jet), this will be on the order of a 0.0156” change between drill bits- which is HUGE (~40%) change in metering area when in the 0.070” jet orifice range. It is for these reasons there is no practical way for a person to casually drill a jet and have any way of knowing what the flow is going to be. Drilling out jets is a holdover from the dark days when guys were struggling to make “high performance” engines live, and if they got within 10% of ‘right’ they were at the top of the heap. Nowadays, thankfully, we all (should) know better and leave the drilling of jets and other dubious practices to the desperate, the uneducated, and the poverty-stricken. |
| New Demon "Street Demon" 625cfm carb | Motochris | Engine | 6 | 10-10-2012 12:04 AM |
| 350 carb question demon carb to much? | Studedean | Engine | 5 | 04-22-2012 12:44 PM |
| Demon carb | chris26lee | General Rodding Tech | 1 | 06-12-2011 11:20 PM |
| Need a little Demon carb help | PatM | Engine | 6 | 01-31-2006 12:33 PM |
| Demon Carb. | deno | Engine | 12 | 01-03-2006 03:55 PM |
