Demon Carb
Does anyone have experience with a Demon carb? I am now using an AFB (really, not an edelbrock) and wonder if I can gain anything by going to a similiar CFM Demon. The design with the blended and smooth bores seems like it would in itself make more HP. I have shied away from Holleys due to leakage, but it looks like these other folks have solved that problem. I have always liked the fact that one can change jets and metering rods on an AFB type without loosing fuel and removing the carb. Thanks, Uncle Rich
Are you referring to the new "Street Demon" 625 carb? That's the only Demon that uses metering rods. The rest are much like a Holley.
Here's a quick review I did on the 625-- New Demon "Street Demon" 625cfm carb |
I have an 850 Mighty Demon on my big block engine. I bought it back in 2005 I think.
Things I had to do to it: Send the metering blocks back for exchange because the idle screw holes were drilled improperly. ( they were offset, they didn't line-up which caused the idle adjuster needles to break when you screwed them all the way in ) Change the power valve. Change the jetting. ( It was ridiculously pig-rich. Came with 86pri and 94sec jets. ) Add notched float and jet extenders on the secondary side. After all that.... it works great now! lol |
I've used holley's too and while they have a LOT more aftermarket support and options they really don't preform as well on a MILD STREET engine. A race engine is a different story. I never saw the appeal of a quadrajet. |
no, not really. You can tune any carb to get close to the desired AF ratio you want, and a BOX STOCK 1406 is pretty damn close on most mild 350's- for a cheap carb that is.
Demon carb
Actually, I was looking at a Speed Demon 650 cfm electric choke. I was hoping to improve the performance of my 400 Pontiac over what the AFB provides.
I, like gearheadslife, think that the Quadrajet is the best street carb ever built. Because it has an air valve controlled secondary, you can't be over carburated. Once you get it tuned, it will do an excellent job!
Bill
as does every carb with a vacuum secondary... the edelbrocks and the new demon 625 has secondaries that work off of airspeed instead of vacuum signal (like a holley), but either can be tuned to deliver the same results.
get from a square bore carb |
| New Demon "Street Demon" 625cfm carb | Motochris | Engine | 6 | 10-10-2012 12:04 AM |
| 350 carb question demon carb to much? | Studedean | Engine | 5 | 04-22-2012 12:44 PM |
| Demon carb | chris26lee | General Rodding Tech | 1 | 06-12-2011 11:20 PM |
| Need a little Demon carb help | PatM | Engine | 6 | 01-31-2006 12:33 PM |
| Demon Carb. | deno | Engine | 12 | 01-03-2006 03:55 PM |
