Demon Carb. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 02:20 PM
Demon Carb.
Hi, this is deno. I would like to find my carb. identification #s on my Demon carb. It is either a mighty Demon, or a race Demon. I looked all over, and cant find the #s. Thanks , deno
Old 12-29-2005, 04:08 PM
73oldsman's Avatar
Did you check the BG site to see if you can ID your carb by picture? http://www.barrygrant.com/
Old 12-30-2005, 05:45 AM
Demon Carb
Yes I did and it looks like a Mighty Demon. They don't show where the Identification #s are. The #s are on the carb, but I cant find them.
Old 12-30-2005, 12:21 PM
73oldsman's Avatar
You aren't the only one who can't find a #. I went out a looked at my Road Demon and couldn't find a find one either (carb installed). I got out the paperwork and instruction manual that came with the carb and once again - no number. The manual does read "Road Demon" though. I haven't had a reason to tear into it, but I'm thinking of rejetting this weekend. I'll look closer then.....
Old 12-30-2005, 12:51 PM
Demon carb
Hey 73 Oldsman, this is deno. I had called some carb guys, ond one told me that there are two numbers on top by the vent tube. my numbers are 56. He told me that it was an 850, but he didn't know if it is a race Demon or mighty Demon. Thanks---
Old 12-30-2005, 04:27 PM
73oldsman's Avatar
O.K. I found the number 9 by the vent tube. Don't know what that means and the site didn't help much....http://www.barrygrant.com/demon/default.aspx?page=3
Old 01-02-2006, 09:25 AM
Technical Support Barry Grant
Demon carburetor identification.
Demon carburetors are identified by markings stamped into the main body next to the secondary vent tube as well as their appearance. The following link can help you determine which Demon carburetor you have.
http://www.barrygrant.com/demon/default.aspx?page=38
Old 01-02-2006, 09:58 AM
73oldsman's Avatar
Thanks Tech@BG. I knew you were out there somewhere!
Old 01-02-2006, 12:42 PM
Glad to help.
Old 01-02-2006, 01:37 PM
re: DemonCarb,
Hi, this is deno, I don't know if I have a race Demon or a mighty Demon. They look the same to me. next to the air vent I have two numbers 56, then a small drill mark next to the 6. Do you know what I have ? Thanks deno---
Old 01-03-2006, 05:46 AM
Which Carburetor?
Deno,
The 56 tells us that it is a 1.562" Venturi, and the ball mill mark indicates that it is a Mighty Demon series carburetor. It would be an 850 Mighty Demon.
Old 01-03-2006, 03:31 PM
re:Which carburetor
Hey Tech @BG, this is deno. Thanks for the info. You knew exactly what I wanted. Thanks again deno---
Old 01-03-2006, 03:55 PM
No Problem Deno.
625 Road Demon Jr. Problems!!!! Grant209 Engine 39 01-15-2006 07:21 PM
Barry Grant Demon carb gilby246 Engine 4 03-24-2005 12:12 PM
carb selection 4 in mind, demon holley or edelbrock? Jared Engine 6 06-18-2003 12:55 AM
Adjusting a speed demon carb Bradless Engine 2 01-03-2003 03:29 PM
Road Demon Carb Vaccum Connection js34Ford Engine 15 12-06-2002 08:31 PM
