Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Demon carb help
Thread: Demon carb help
Old 12-18-2011, 03:25 PM
Blown Camaro Blown Camaro is offline
Last journal entry: Before the 6-71 cometh
Fixed!
I thought about what the engine was doing and why it was rich/lean/rich/lean ect. Woke up at 3:30am with the solution! Couldn't start car because of the neighbors so had lots of coffee.
Here's what I did:
Fixed! Posting this so I can help the next guy that does an internet search. Here's what I did:
Started off with the idle screws out 1 1/2 turns, had a 500rpm blower surge when engine is hot.
Ended up with idle screws at 1/2 turn each, and closed primary throttle blades 1/4 turn. OPENED secondary throttle blades 1/4 turn.
Engine now idles at 1200rpm with maybe a 50rpm surge or less. No smoke, no miss. Drop it into gear and it idles smoothly at 1100rpm.
HAPPY!
