Demon carb identificaiton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 02:28 PM
Can anyone identify this Demon Carb? I cannot locate any numbers on the carb, and none of the info on their website helps me. It's running very rich and I have no idea how to know it's cfm or how to adjust. Thx in advance.
Old 07-04-2012, 02:31 PM
Can anyone identify this Demon Carb.
Here are the pics!
Old 07-04-2012, 04:21 PM
S10 Racer's Avatar
http://www.warsprints.com
I don't see any pics
Old 07-05-2012, 06:30 PM
Having a hard time getting the pics under 3 megs
Old 07-05-2012, 06:33 PM
ericnova72's Avatar
More for Less Racer
Looks like either a Road Demon or Road Demon Jr. No idea on size just from that picture.
Can't tell you for sure unless you post the #'s off the drivers side of the carb main body.
Old 07-05-2012, 06:46 PM
Here's a few more
ID:	66579   Click image for larger version
ID:	66580   Click image for larger version
Old 07-05-2012, 07:05 PM
ericnova72's Avatar
More for Less Racer
Like I said, it's a Road Demon of some sort, no one can tell you size without the ID #'s...or measurements of throttle blade diameter and venturi diameter.
Just pictures is only going to get you so far in identifying it.
All adjustments are just like a Holley 4 barrel.
Old 07-05-2012, 07:36 PM
OK, I'm going to look for some identification numbers on the driver's side of the carb. Thx.
Old 07-05-2012, 07:44 PM
DoubleVision's Avatar
The rear boosters are annular. If the primaries are annular, it's a road demon jr. 525.
If the primaries are downleg boosters along with the rear annulars, it's a Road demon Jr. 625
It has to be one of the two as if I recall correctly the road demon jr. 725 had primary and secondary down leg boosters.
Old 07-05-2012, 10:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's a road Demon Jr. as DV said. It's either a 625 (#6 w/dimple) or 725 (#7 w/dimple), due to the downleg primary booster along w/the straight leg secondary booster.
The size ID is also located on top of the carb , see the drawing below:
Old 07-06-2012, 07:06 AM
Thx for this information. I think I can figure out exactly what I have now!
350 carb question demon carb to much? Studedean Engine 5 04-22-2012 12:44 PM
Demon carb help Blown Camaro Engine 3 12-18-2011 03:25 PM
Need a little Demon carb help PatM Engine 6 01-31-2006 12:33 PM
Demon carb help musky2 Engine 2 09-04-2005 09:58 AM
