http://www.barrygrant.com/pages/news...id=IdleEZSolve
"Since all Demon carbs (including their predecessor the Claw) feature four-corner idle-metering circuits" |
I run the 625 cfm Road Demon Jr. With a few problems at first just because i was new to 4 barrel carbs but it runs good now. I am going to get the 750 cfm speed demon for my 385 stroker.
Re: Demon carb questions
Before you go spending money on a carb, I would recommend that you do a little research on BGs site etc.. |
sounds lke the street avenger wasnt selling. the demon is a superior carb. i dont know what this idle problem is, set up is a little different than a holley. the metering circut is way more sensitive. my demon 750 carb is very smooth/and responsive ,not on or off at all. i would suggest to anyone who looking for a close alternative to a holley.
by the way i havent had any leaks,with the demon |
Re: Re: Demon carb questions
and it wasnt a sales pitch, he had a truck avenger in stock and that was it. he would rather me spend more money on the demon. but he knows me, he's one of my dads good friends, he was just giving me his expierences with the demon product line. |
This is just what I don´t need, after looking at all my options I just ordered a Speed Demon and an Air Gap manifold to sit it on.
The only problem I see with this carb is where do you hook up the vacuum line for power brakes? |
same place?
I went with a road demon jr. 625, it idles fine, and responds fine.
I didn`t go with a Holley since they have poor quality control, the base plates are known breakers, while the demon plate is made of billet and is unbreakable. Truth is, many don`t like Demons because they don`t know how to tune them, you can`t do a demon as you would a holley or another carb, it`s very precise, but once it`s set it`s set. If you do go with a demon you won`t be unhappy, but make sure you read the instructions that come with the carb, and go over them real well and follow everyone, if you miss one step the carb won`t be right. I`ve seen many slap a demon on, not read the instructions and then call it a piece of junk, it`s not the carbs fault if the installer don`t know how to tune it. |
Our carburetors are more calibration specific than our competitors. This generally gives use better performance if they are installed on the application they were designed for, but also means if the carburetor was incorrectly sold, or picked they will not perform as well as they should. We also do continual research and development on our products, and update them as we find better calibrations, and components. We upgraded the Baseplates on our Speed Demon, and Mighty Demon series carburetors to come with our Idle-Eze® system almost a year ago now. This system helps adjust the carburetor easier if the specifications on the engine may be a little outside the range of where the carburetor was engineered to work. If you’ll contact our technical department directly at (706) 864-8544 we can help you determine which carburetor is going to give you the best overall performance on your combination
I run the 625 Road Demon on my Malibu.It is always there when I touch it,drops off when I let out of it.Response is terrific.Real good product.
thanks everyone for all of your help, he must have not delt with demon carbs in a while, because im sure he is unaware of the Idle-Eze system that comes on them now. so thanks again to everyone that helped me, this site is great.
Idle-Eze
The Idle-Eze is an air bypass system that is in our carburetors that eliminates the need to drill holes in the butterflies to get the carburetor to idle properly. We have information about them on our website at www.barrygrant.com An 850 would seem extremely large for an engine that small. IS this something you had from another project?
Re: Idle-Eze
