Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - demon carb stumble @wot
Old 09-13-2012, 04:52 PM
cdminter59 cdminter59 is offline
demon carb stumble @ wot
Be sure to check all ignition components carefully. Distributor cap, rotor, correct spark plugs gaped at .035, make sure spark plug wires are not touching headers. Timing set at 24* BTDC. Check valve lash again. Here is the manual for the Mighty Demon. It shows how to tune your Demon carburetor. http://www.demoncarbs.com/Assets/doc.../LIT705rev.pdf. You will need a vacuum gauge and a timing light with advance. Here is another article on how to set up your distributor. http://www.crankshaftcoalition.com/w...EI_distributor
The Following User Says Thank You to cdminter59 For This Useful Post:
bill6368 (09-13-2012)
