demon carb stumble @wot - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2012, 11:30 AM
bill6368's Avatar
i got a 355 sbc foot brake car i put a 750 mighty demon on it im having a dead spot @wot then it picks up an does fine ive tried the slot transfer seems if i close it up where it needs to be it idles at very low rpm also the air fuel mix screws if you turn them all way it seems to idle up the motor
Old 09-13-2012, 01:55 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Disconnect the vacuum advance and bring the timing more advance another 10*. Adjust the idle down. Reconnect the vacuum line. The idle should increase when you advance the timing. Try to adjust A/F screws.
The Following User Says Thank You to lg1969 For This Useful Post:
bill6368 (09-13-2012)
Old 09-13-2012, 02:07 PM
bill6368's Avatar
Im not running a vac advance got it plugged off you think i should hook it back up
Old 09-13-2012, 02:18 PM
lg1969's Avatar
What is timing set at?
Old 09-13-2012, 02:25 PM
bill6368's Avatar
Im not sure ive tried it at dif spots it stumbles even in park a little but its worse when i leave out the hole
Old 09-13-2012, 02:34 PM
bill6368's Avatar
last it was checked using a light it was @26 deg
Old 09-13-2012, 03:52 PM
demon carb stumble @ wot
Be sure to check all ignition components carefully. Distributor cap, rotor, correct spark plugs gaped at .035, make sure spark plug wires are not touching headers. Timing set at 24* BTDC. Check valve lash again. Here is the manual for the Mighty Demon. It shows how to tune your Demon carburetor. http://www.demoncarbs.com/Assets/doc.../LIT705rev.pdf. You will need a vacuum gauge and a timing light with advance. Here is another article on how to set up your distributor. http://www.crankshaftcoalition.com/w...EI_distributor
The Following User Says Thank You to cdminter59 For This Useful Post:
Carb stumble Hwyhogg Engine 8 12-16-2011 08:22 PM
Weber carb suddenly going to WOT EOD Guy Engine 18 08-25-2010 07:18 PM
wot stumble prob 87fubar Engine 6 06-07-2010 08:17 PM
carb stumble under medium accelation hatrecide Engine 21 10-07-2009 04:11 PM
Demon Carb Off-Idle Stumble - Help leejoy Engine 3 06-25-2007 06:14 AM
