Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Demon carbs lean at transition
Old 03-31-2013, 05:14 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
You only need to richen it up a bit. It won't surge.
Do not attempt to target a particular AFR at idle. Give it what it needs.
Surge at idle is real fat or real lean.
Do yu have a boost retard box? if so set the timing to 34BTDC and take timing out as boost rises, with the box.
