Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Demon carbs lean at transition
Old 04-14-2013, 04:56 AM
Blown Camaro Blown Camaro is offline
Last journal entry: Accessories can drive you mad
Originally Posted by F-BIRD'88 View Post
Good stuff...
Adding a boost retard box will allow more idle and part throttle timing when not under boost
which will idle and drive nicer.
Right now I have a switch that cuts 4 degrees but I have to remember to flip it! I need to hook up a MAP sensor to this Mallory 685 box.
