Demon carbs lean at transition - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-14-2013, 02:17 PM
Last journal entry: Before the 6-71 cometh
Originally Posted by F-BIRD'88 View Post
Why not employ a WOT throttle switch to switch on the retard at say 1/2 to 2/3 throttle
Or a simple hobbs manifold pressure switch say 3psi so you don;t have to "remember"
Hey, that's a great idea! I am going to try that. My blower goes instantly to 10psi at full throttle then climbs to 11 so I think that switch would work great.
BTW, just got home from the track. AFR is 12.7 under boost I think it's lean! But at 3500 cruise it is 11.5 so I think I am going to pull 4 numbers from the primaries and add 6 to the secondaries. What do you think?
  #17 (permalink)
Old 04-14-2013, 06:13 PM
F-BIRD'88's Avatar
Yada Yada Yada
Increase all the jets till you get the best track MPH. and look at all the plugs
Then go back and retune the primarys part throttle as required.
The afr gauge is just a guide. (to avoid excessive lean)
You may be actualy cruising on the idle circuit. may have opened up the IFR a hair too much now.
Transition circuit on Holley 4160 too lean. johnt365 Engine 1 02-17-2013 12:11 PM
M Demon lean out of the box?? rsk289 Engine 3 07-11-2010 09:50 AM
Super lean part throttle on a demon - help! hotrodf1 Engine 11 09-17-2007 12:13 PM
Problem: Temporary lean out - 406 with a demon hotrodf1 Engine 7 12-20-2006 03:07 PM
750 Demon - lean from factory? hotrodf1 Engine 13 08-30-2006 01:57 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
