Demon carbs mounted sidesaddle-need to cut bracket?
I'm fitting up my dual Demon carbs to my blower and have run into a small problem regarding throttle bracket clearances. On top of the blower is mounted the carb adapter for 2 4-bbls. The front carb fits just fine on the adapter plate, but the rear carb doesn't fit because the bottom part of the throttle bracket hits the top of the adapter plate. The front one fits since it hangs out over the front of the plate.
I'd like to just cut off the bottom of the bracket on the rear carb for clearance, but before I do, I'd like to get a few opinions. I don't want to go with any spacers between the carbs as the whole assembly is very tall already. The only thing that I can see is that I won't be able to use the hole for the throttle return spring. My return springs were going to be mounted elsewhere anyway. I've attached a pic showing what I'm talking about. Anyone see any reason why I shouldn't do this? Thanks! Steve |
There's no reason you can't trim it. I've got the same setup on mine but did use carb spacers, heck, what's another inch, he he!
Same problem with Holley 750s
Had the same problem with the same piece on my rear Holley 750 and the blower adapter. Just cut what is needed, no problem. Mount the return springs using a mounting kit through the big holes on the same piece.
Good deal! Thanks to all who replied.
Steve |
| "Basics of Basics" Sectioning a Body | MARTINSR | Body - Exterior | 7 | 11-24-2008 12:04 PM |
| Chop and channeling. how to....? | baugh353 | Body - Exterior | 15 | 02-07-2006 07:21 AM |
| Question about removing roof | 86caprirs | Body - Exterior | 3 | 03-27-2005 12:21 PM |
| Demon carbs..?? | Dave Y. | Engine | 8 | 05-19-2003 02:02 PM |
