Demon throttle shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2011, 05:12 PM
Well, I went and proved I shouldn't be allowed to handle things that I can drop.
I dropped my Demon and bent the primary throttle shaft. Now the butterflies hang up.
Anybody know a source for Demon throttle shafts? Will Holley parts work or you think it's posssible to straighten the shaft with a brass drift and a small hammer?
I'm open to ideas.
Thanks
Old 06-06-2011, 05:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I'm open to ideas.
Thanks
I do know some parts will interchange but not real sure about the throttle shaft. But you should be able to straighten it out i would think. JMO
do you have a Holley to compare it with i know the throttle blades are put together with different type of fasteners one has screws and the other has to be mushroomed to hold them in. IIRC
Cole
Throttle cable on Demon Carb david-b Engine 15 11-09-2010 02:48 PM
Demon carb throttle bracket david-b Engine 7 10-28-2010 11:06 AM
Q-Jet Throttle Shaft beertracker Engine 5 05-11-2010 08:40 PM
speed demon - throttle shaft bushings or bearings? 60smotorhead Engine 3 07-26-2009 02:30 PM
Super lean part throttle on a demon - help! hotrodf1 Engine 11 09-17-2007 12:13 PM
