Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dent
Thread: Dent
Old 10-04-2002, 10:15 PM
ponchowerx ponchowerx is offline
Can you get a prybar behind there and bang it out with a hammer? [I assume your jack is alot bigger]. If not try to tack weld a piece of metal[angle, flat bar on edge] to the dent, drill some holes in it and yank on that instead, either by a chain or bars inserted into the holes or even your slidehamer. A pull on a larger area will help on this hard dent.After just grind it off. Just my .02
