Dents in Chrome Bumpers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2007, 11:20 PM
Is there any way at all to take out a dent in a chrome bumper piece from the 50's? Will it crack the chrome? Can you heat the back side and "press" it out? The chrome did not crack or split at the dent.
Old 05-29-2007, 08:24 AM
In a word, no. It is easy to repair it, but it is replating time after.
Old 05-29-2007, 09:23 AM
I see what you mean. I did mean Can I fix without rechroming.
Old 05-29-2007, 07:59 PM
Well, you know, I understood the question and my answer was "in a word, no". But I have to tell you, it depends on what your expectations are, your patience, and the dent. You "could" slowly massage the thing out I assume. I failed when I have tried it, but I guess it's possible.
Old 05-29-2007, 11:41 PM
Brian, what happens when you "fail". Does the chrome crack off or what?
Old 05-30-2007, 03:51 AM
I saw a fellow make an acceptable, to him anyway, dent repair in a chrome bumper by placing a piece of hardwood on each side of the dent then using a heavy C-clamp he pressed most of the dent out. He then placed soft shims under the edges of the outside piece of wood then with the inside piece still against the "bump" side of the dent he slightly over bent it so that when he relaxed the pressure it returned to pretty much flat, not absolutely perfect but not bad either. If your chrome is not already damaged this might be worth a try.
Old 05-30-2007, 07:51 AM
When I tried, the chrome didn't crack, the dent was just turned into a "different dent" that's all.
47-53 Bumpers Chev Truck ? Nailhead2x4 Hotrodders' Lounge 4 03-03-2007 04:59 AM
removing/painting over chrome that is pot metal? 72helpneeded Body - Exterior 7 05-27-2006 09:09 PM
Painting chrome wp442 Body - Exterior 5 12-14-2003 10:35 AM
Stripping chrome bumpers greene50's Body - Exterior 3 09-15-2003 12:11 PM
painting old chrome bumpers zonk Body - Exterior 3 01-07-2003 06:16 AM
