Design problem with front shock mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2007, 03:29 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
Hi, kind of hard to explain this problem. I don't know where to look for help, maybe you folks can guide me to an answer.
Im trying to install some gas shocks in the front end of my 39 Pontiac. The rear of the bottom control arm needs the bottom shock mount, the top mount will come off the frame...kind of stick up above it. I can measure how much up down movement will happen...I've sized the shocks for one inch more travel than that extreme. However, how do I guess how far the shock will move in/out...that is, left to right when viewed from the front of the car?
The upper control arm, brake line, tie rod, all that stuff makes it tough to figure out where to put the upper mount.
I could take out my spring and test the shock after I weld up mounts, but the shock is a gas shock and resists my efforts at shoving it closed.... And pulling the spring is not that fun...
Any ideas on how to install my new shocks?
Richard
Old 04-25-2007, 07:38 PM
walt's Avatar
When the car is at ride height the shock should be at half travel.
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
72 Nova Rear Shock Mounts Relocating leejoy Transmission - Rearend 6 04-26-2006 10:16 AM
Front leafs...moving mounts UP? unstable Suspension - Brakes - Steering 4 10-15-2004 08:19 AM
front shock mounts 33 Forf P/U homer Suspension - Brakes - Steering 0 10-29-2003 10:36 AM
Front shock mounts homer Suspension - Brakes - Steering 1 10-29-2003 09:11 AM
