Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Designing my own scratch built Rat Rod, need guidance on where to start
Old 12-21-2005, 06:45 PM
Nightfire's Avatar
Nightfire Nightfire is offline
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
No probs man, us young guns gotta stick together
Here's a few pics of totally home-made bodies...these are scratch built except the cowl (front part). You can find cheap cowls from the 20's and 30's and build your own rear half, really easy if your making it a roadster with no doors. I also threw in a pic of some model A cab measurements
Also check this out...that should give you an idea.
Building your own frame, front axel and radius rods will be your cheapest bet in the long run. Get a cheap GM 10 bolt rear from the junkyard...they're found everywhere and perfect width for the T frame plans. Get a cheap cowl (look around, scrounge, do whatever you have to do, I got a t-bucket body for $90!!! Check out ebay, 20's dodge cowls are pretty cheap too since nobody has use for them) then build your own backhalf. The 318 with the 3-speed auto is a good choice too. Have fun and show us pics!
Mike
EDIT; the other pics didnt work sorry, I'll work on it
