Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Designing New Garage
  #197 (permalink)
Old 03-18-2009, 09:32 AM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by desertdave
Roger, why did you use 2 primers? Why not just the SPI epoxy primer instead of adding the polyester primer as well? Just curious
There were some dings and dents that I had to knock out and I needed to block sand them to get them perfect.
The Evercoat Slick Sand polyester primer is a real high build and works real well with block sanding panels perfectly smooth.
I could have block sanded with the epoxy primer, but it would have taken a few more coats.
