Elect panel code requirements
Your shop looks excellent, Mine is a tin building and it gets very cold in the winter... Your electrical panel is very neat, better than a lot of pro jobs I have seen...BUT the white wires going to the circuit breakers. If they are current carring conductors ( a feed to a 220 outlet for compressor- welder. etc) the electrical code requires they be painted/ taped some other color and the other end of the conductor at the device box also needs to be marked...Green is reserved for the ground. bare copper is ground... white is reserved for only the Neutral wire . yellow should not be used for the current conducting wire since some warehouse type lights make white and yellow hard to see which is which. the problem is that in the future someone else could get shocked touching a white wire.thinking it is a neutral wire...
depending on what it would take and if you have the power i might suggest you look into a tankless water heater. it takes up much less space and even if you used 4 hours of hot water every day you would still save around 7500 hrs of electric a year.
Now that you have this unbelievable shop, it must be time to get a new rod project right? You instilled so many ideas that I wanted to use, but $$$$ and family seemed to change the plans. Great work!!!!
Update
For the 660 square foot main area, I just ordered Wolverine epoxy from the AlphaGarage supplier yesterday. I ordered light gray with white, black and dark green flakes. I upgraded to their urethane clear coat instead of clear epoxy for the topcoat. I did a lot of research and it seemed they have an extremely high quality product for a reasonable price. Their epoxies are 100% solids and the urethane is 90% solids. I will have a total thickness of about 26 mils. I have already prepped the concrete by grinding instead of using acid. I used a 7" hand grinder with a diamond cup. It took me about 15 hours over 3 days to grind the 660 sqft. Btw, I completed the outside painting last week. Still waiting on the cabinets. Looks like next week for sure. I will have to paint them after they get delivered. I am sure that will take me 3 or 4 days to do. |
roger, throw those flakes away ! i used them in my build room and absolutely hate them. you drop something small you'll never find it .
I appreciate the advice and have given this some thought. I didn't use the flakes in the clean room, compressor and blaster rooms and those rooms are already done. If I build a car along with any kind of work that will create dirt, dust or overspray, it will be in the 14X24 clean room. (I call it the clean room only because it will be simple to clean.) I used a marine type of oil based paint for the walls and ceiling so this room can be washed down if necessary. For the floor, I used the single coat EpoxyGuard epoxy so it would be easy to repair or re-coat if it ever gets damaged. When I do occasionally paint a car, I will be able to cross vent it with a filter set up like a paint booth. I am going for good looks in the large main area. I will do occasional mechanic type work in the main room but I will just have to put up with the inconvenience of finding small dropped items. If I built an engine or something like that in there, I could get one of those large vinyl mats. And, I'll keep one of those pole magnets handy. |
Update
I got the cabinets painted and installed. (I still have to paint the drawers and doors.)
![]() ![]() Now I am ready for the epoxy floor. The epoxy is on order. Here is a thread over in the "Flooring" section of the Garage Forum where I am documenting the epoxy job: http://www.garagejournal.com/forum/s...ad.php?t=26308 |
OK - OK - just stop already
Wow - this place is nicer than my home! Really nice work and attention to detail! Are you really going to be able to "dirty" it up and do any work in there? |
Here's my shop with the first snow of the season just starting to fall. This building is 1500s.f. I've got two out buidlings and a 4 car attached garage. Still not enough room. If I were you I would go for a 12 foot ceiling to accomodate a lift. ...you can never build it big enough...
You bet I'll do some work in there. The clean room (aka dirty room) is where the heavy duty work will get done. |
First class job,
Update
Finished painting and installing the cabinet doors and drawers.
That was a lot of work. Sprayed them with oil based, inside and out. I also have attached 1 1/8" OSB for the workbench tops. I am going to put black/white (checkerboard) 1/8" VCT tile on it. I am planning on cutting the 12" tiles into 6"X6" pieces. Then I will coat the tiles with clear urethane. I also have on order some 1 1/4" polished aluminum counter edging for the top edges. I am ready to epoxy the floor when weather permits. ![]()
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| Maiting calls of the garage | Halloweenking | Hotrodders' Lounge | 22 | 09-19-2006 09:18 PM |
| Garage Safety | Kevin45 | Garage - Tools | 48 | 11-26-2005 08:49 PM |
| Hotrodders Knowledge Base: Garage - Tools | Jon | Garage - Tools | 0 | 11-26-2005 06:46 PM |
| Some more ideas for the garage | Kevin45 | Garage - Tools | 7 | 01-28-2004 11:36 AM |
