Designing New Garage - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 05-09-2008, 06:28 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The beams are 24" deep and 12 feet apart which exceeds the code for San Angelo.
Not dissing.. ....Just comparing codes and differences in different parts of the USA I have never seen beams built under the garage floors like that, unless the beam was going to support some excessive weight like a lift attachment point or monstorous machinery mounting point. (of course, I am taliking about garages with trussed roofs and no load bearing walls inside)
Here in my state, a hobbyist garage might go to 6" thick floor, but surely never having beams out in the middle like that....and it's super rare "here", to see rebar either! I think the concrete mix is special to allow no rebar...I am pretty positive on that. Residential garages are likely 4" with no beams, just frost walls on the perimiter only.
We have codes here for frost wall depths of 42"... but there is supposed to be a new system around here to allow buried rigid insulation placed at 45* angles downward around the perimiter, that allows way less of a frost wall depth.
Hey Roger, I've been following your build from the initial planning. You yakking about the old service station look, now has me hooked on trying to put a similar facade on my existing shop....a porch overhang with that same roofing ...and one of those nice doors you showed ..thanks for the inspiration
  #62 (permalink)
Old 05-09-2008, 08:09 AM
dinger's Avatar
Originally Posted by 1ownerT
I hate to say this, in 28 years of working construction I have never seen a slab prepped like yours.
What is under the poly?
It may be deceiving but it looks like a lot of the rebar is laying on the poly.
There should be two #5's min. in the thickened edges, rebar should have a min. 3' clearance from the dirt.
If you stretch a string line from side to side, what do you have for concrete depth?
I think some areas are requiring prep like this to prevent subterranean (sp?) termites. They've been a problem in Ca. when building over old orchards. The soil is treated, covered and then concrete laid. Don't know about Texas tho...
  #63 (permalink)
Old 05-09-2008, 08:25 AM
roger1's Avatar
Termites are a horrible problem in San Angelo.
That's why I went beyond code. I used 2X8 forms when only 2X6 were required. The vapor barrier wasn't required either but I wanted that and I did do the termite treating prior. The 2 beams going across the short side weren't required but the one down the center on the long side was.
It seems like when doing a foundation, it is better to err on the side of overkill vs. the other way around. This is an expensive foundation tho.
Should have a couple more pics today of the pouring. I am out-of-town on business today, so my wife will be conducting things. She just called and said the city gave us the green tag. I hope she gets some good pics.
  #64 (permalink)
Old 05-09-2008, 07:32 PM
roger1's Avatar
Ok.
Got it poured today. Looking good IMO.
  #65 (permalink)
Old 05-21-2008, 05:20 PM
roger1's Avatar
Framing has begun!
It's getting exciting.
The gas pump island is scheduled to be poured on Thursday.
Here are pictures from today:
  #66 (permalink)
Old 05-21-2008, 06:00 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
looking very good!!!!Wish it was in my yard.
  #67 (permalink)
Old 05-27-2008, 08:05 PM
roger1's Avatar
Coming along
Still don't have the pump island poured. My concrete guy has skipped town.(Or maybe back in jail.) Others have chipped in to help us get that done. Hope to get it poured by Thursday.
  #68 (permalink)
Old 05-28-2008, 02:12 PM
I get more and more jealous every time I read through this thread. Starting to look like a shop now.
  #69 (permalink)
Old 05-29-2008, 05:49 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
That's a huge skylight you have there.
J/K
Looking good, keep up with the pix.
  #70 (permalink)
Old 05-29-2008, 07:37 PM
roger1's Avatar
Progress through 5/29/08
Finally, the island is poured!
  #71 (permalink)
Old 05-29-2008, 08:07 PM
F&J F&J is offline
I see conduits for wires and lights...that's going to be so cool at night with the pump dials lit up.
  #72 (permalink)
Old 05-29-2008, 08:28 PM
roger1's Avatar
Thanks!
The pipe on the left is water and the one on the right is air.
The one in the middle will be for wires to light up a gas pump.
  #73 (permalink)
Old 05-29-2008, 09:11 PM
Man it sure is coming together.
  #74 (permalink)
Old 05-29-2008, 09:29 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Looking good!
Are those the roof trusses?
I certainly have never seen that kind of comstruction before.
Is it not going to be a peaked roof?
Here is a picture of what my (4:12) trusses looked like.
  #75 (permalink)
Old 05-29-2008, 09:52 PM
roger1's Avatar
Those are I beam joists due to the span.
It will be an 8 pitch roof.
The rafters will go on tomorrow.
I'll post another pic at the end of the day.
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Some more ideas for the garage Kevin45 Garage - Tools 7 01-28-2004 11:36 AM
