Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #121
Old 08-29-2008, 01:32 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
re: Designing New Garage
I'd go with Wolverine Coatings. As far as color, somewhere I have a bookmark with probablt 50 different colors and chip combos. When I get home from work (just getting ready to leave the house) I'll send it your way.
Old 08-29-2008, 07:03 AM
trees's Avatar
trees trees is offline
Roger, Tennant Floor Coatings is probably the best you can get, but may be expensive. Years ago before retirement, I had a big aircraft hanger and all the support shops coated with Tennant and they still looked like new 6 years later. There was a 16 ton aircraft tug with chains on that pulled an airplane into the hanger, turned around and departed before the guys could stop him but he did not damage the coating!!! Their contact number to locate a distributor etc is 1-800 553 8033. I plan to use their product on my floor if I can afford it. We will go with a light gray or tan. My son is big on making sure it does not cause light distortion to screw up paint colors. He has young eyes that can tell the difference, I guess.
Trees
PS If you are going to use a floor coating, don't apply a sealer, otherwise you will have to acid etch to remove it!!!
Old 08-29-2008, 07:18 AM
shine's Avatar
shine shine is offline
roger, call barry knives at spi. the price is half of what you see elsewhere. it's just epoxy. one note, the cute little specs the sell to throw on the floor make it impossible to find something you drop ask me how i know.
Old 09-17-2008, 09:28 PM
roger1's Avatar
roger1 roger1 is online now
I haven't decided on my epoxy floor yet.
But, I have decided to prep the concrete by grinding it with a diamond wheel cup versus using an acid etch. After I grind it, if I like the way the floor looks, I may consider just using clear epoxy. I have contacted the supplier for Wolverine coatings and their clear seems to be designed for good adhesion since it is used for primer also.
Update:
I have been working on taping and floating (done), installing lights (also done) and inside painting. Also, the restroom tile job is still ongoing. I am working on cabinet designs and will get those to a cabinet maker soon.
I'll post new pictures in a few days.
Old 09-23-2008, 01:21 PM
Knight_4000's Avatar
Knight_4000 Knight_4000 is offline
Looking real nice there! Keep up the good workmanship. I would put a lift in if you want to do any car work. All the big tire places usually shift out theirs on a cycle so you can get a nice used one cheap, or if you have the money you could get yourself a new one too. It saves you alot of time that you would normally be VERY painfully streached under a car if you are working on one. And there is a ton of other uses you can put those things too.
Old 10-21-2008, 12:27 PM
roger1's Avatar
Updated Pictures
Things seem to be moving along slow at this point.
There is still much to do but I am doing it all myself since the contractors finished their part.
Here is the outside. I still have to do the painting. Then the fun job of finding a gas pump, signs and nic-nacs. Had a couple of loads of caliche fill hauled in to smooth it up around the building. Still some more work to be done though.
Here are a couple of shots of the 14X24 clean room. It is done. I just finished putting an epoxy floor down on it. I used EpoxyGuard. Put lots of lighting in there too.
Here is a shot of the blaster and compressor rooms.
They are done too. I put Quikcrete epoxy on those floors.(2 coats of color and 2 coats of clear.)
Here are a couple of shots of the restroom. One though the outside door of the building and one through the inside door.
It is done except for some trim painting and I ran out of epoxy grout for the floor so a little more to do on that.
There is still a lot left to do in the large (660 sq ft) area.
I need to decide what to do with the floor. I am leaning towards using the Wolverine epoxy system unless I get talked into using Racedeck.
Also, I am going to have custom floor and wall cabinets built for the south wall.
Here is what it is looking like now. I got all the lighting done.
Electrical final passed and am ready for plumbing final and construction final.
I used my extreme wide angle lens for these shots. It can make things look a little distorted at the edges in case you were wondering.
Old 10-22-2008, 06:11 AM
Kevin45's Avatar
All I can say is WOW and I'm pretty much jealous LOL!! Fantastic looking place.
Old 10-22-2008, 06:09 PM
boatbob2 boatbob2 is offline
boatbob2
Nice Garage........
Hi,Very nice garage,are you sure you want to bring a dirty,nasty hot rod into that beautiful garage??? when your wife spots it,you will be working outside under a tree,she will use it for a girls meeting place !!!!
Old 10-22-2008, 08:28 PM
roger1's Avatar
Thanks guys!
The pic of the outside was not showing up. I edited the post and it is showing now.
Old 10-22-2008, 10:06 PM
timothale timothale is offline
shop
My main shop in central Utah is metal 40 x 120 with minimal insulation .. very cold in the winter even with the wood stove going full blast.. how much head room will you need if you decide later to add a lift. we have 16 ft sides walls, warehouse racking for storage. My wife's farm near yellowstone park shop has a cinder block walls that are filled with ground newspaper insulation that her brother-in-law manufactured...sheetrock ceiling and a gas furnace. an nice place to work but this time of year it is filled with produce we sell to the grocery. that should be gone by january. I have been looking at the ICF type of construction. strofoam block-wall systems filled with concrete. very energy efficient in hot and cold weather. we have been talking about building another storage-shop and Quad Lock is almost a do it yourself except pumping in the concrete.
Old 10-24-2008, 03:28 PM
roger1's Avatar
Cabinet Plans go to the cabinet maker on Monday
Here are my cabinet plans. I'll give them to the cabinet maker on Monday with half the money.
My plan is to get the floor epoxied while they are being built.
I will paint them myself with my spray equipment.
White or gray, I haven't decided yet. I do believe I am going to go with light gray for the epoxy floor however.
Old 10-24-2008, 04:57 PM
1ownerT's Avatar
1ownerT 1ownerT is offline
Really nice! First class all the way.
Old 10-24-2008, 10:07 PM
MRGM MRGM is offline
Im trying to have an idea!
just read thru this thing. Very nice.
will give you three cause the cat is with me...
What do the neighbors think?
Old 10-25-2008, 09:40 AM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Congrats Roger1!
From dream to reality ... it's encouraging and inspiring to read and to see it materializing.
Thank you very much for sharing it all!
Old 10-30-2008, 05:19 PM
roger1's Avatar
Garage Doors Painted and Hardware installed
Took me 2 days to sand, primer, paint (2 coats of oil-based) and install the hardware. A lot of work but I am very pleased with how they turned out.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Designing New Garage"
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Some more ideas for the garage Kevin45 Garage - Tools 7 01-28-2004 11:36 AM
