Nice ...
You must live on an acreage, or at least on a very large lot? I had a heck of a time building a 24 x 34 in my back yard. Check with your municipal government to find out their rules before going too far.
something i would do if i were building this garage would be,
instead of closing those two work rooms in completely, why not just have end walls and have them open to the floor, that would eliminate two doors and 14 feet of wall, and i wouldnt have your bathroom open to the shop along with a door to the outside, |
Great looking plan. Just remember ,It won't be big enough. When I built my shop I poured the slab then had a brick layer build a cinder block wall 3 blocks high which = 2 feet,then build on top with standard studs and you have a 10 foot ceiling. This keeps the wood off the ground for washing out shop with pressure washer and doesn't soak bottom plate, also fights termites.
Those old stations are great. Try to put some time into studying old pics on the web to get all the exterior trim details correct, like soffits, roof overhangs, and mouldings. A little thought and a very small extra amount of money can make it a real knockout.
The only thing I am concerned about is your choice of 8' wide doors. I guess it depends on the width of your cars, but I prefer a 9' minimum....but I know that might throw off the proportions of your style. I like 30's-40's style stations, and I'd be at a loss as to picking a garage door style. I think your project is great...I hope you keep posting..
Great looking plan.
Things to think about: 1) I don't know if you are in a cold part of Texas or not. But if you are I would strongly consider putting in in-floor hydroponic heating. It's the biggest mistake I made in my shop - not having it. I'm on my feet a LOT in shop throughout the winter and it gets pretty brutal. The rest of the shop is at 60...but the floor is ice cold. But then, maybe you need A/C more than you need heat. 2) Just be aware, when you put running water and a bathroom in your shop it will most likely bump it into a different category for tax purposes AND for insurance purposes. Both will be more costly than just a plain old garage. At least that's the way it is here in WI. 3) Before you decide on a final ceiling/roof height, think long and hard about a lift and the design requirements for that particular lift...and the vehicles you will be lifting. Some require a 12' clearance to function properly.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Cboy's comment on the bathroom sparked another recollection for me.
According to local by-laws ... each building that has running water has to have it's OWN sewage line. In other words, I couldn't simply "tie it in" to the sewage line to the house. A whole new line all the way from the back yard to the center of the street out front ... 100 feet or so ... was "guesstimated" to cost something ridiculous ... $10,000 +. I thought "For that much I can just run into the house ..." F&J's comment on the 8ft wide doors is bang-on too. I put 12-footers on mine, and it still takes a little manuevering to swing in from the alley with my pickup truck (extended cab - short-box). Pickup trucks usually have some wide mirrors as well ... so unless you want to fold / un-fold mirrors ... you may want wider doors. I am installing overhead infra-red heaters. Unless you are going to keep your garage heated all the time ... that in-floor heat would take a while to "ramp up". I see my garage / workshop as an "occasional" or "weekend" thing ... so I want to heat it only when I need it. I would expect that Texas would have a much shorter "heating season" than Alberta Canada, though. SpeedyDeedy's "curb wall" idea is a good one, too. I had mine (only 6" high) cast and poured with the slab, and then built a 10-ft stud wall on top of that. Pictures are in my jounal. I am STILL waiting for my (9' x 12') garage doors. The gas and electrical are roughed in, the infra-red heater is hung, siding and roofing are complete. I still need to insulate and hang PLYWOOD interior walls ... I'm not using gyprock. I'm also planning to mount my workbench on casters so that I can move it around as needed. I had the contractor cast in some mounting holes in the concrete floor for 4 chain-pots ... for use in anchoring and pulling things with a cable or hydraulic "come-along". I requested LOTS of electrical outlets ... one duplex receptacle about every 4 ft or so for a total of about 16. Two 220-volt as well. One for a compressor, and another for a mig welder. 2 ceiling fans to keep the air moving. Seeing as how infra-red heating is "line of sight" it might be a little chilly in the "shadows" and under the vehicles. The air movement will also help to keep the windows clear. |
You sometime have to deal with the board of health,When you put running water,Don't know about where you are,But here you do.
I am a Hydrologist, so I am an expert on this. I have three water wells on my 4 acre property. Two I use for the yard and one for the house. Don't have to deal with any kind health department at all for private wells in Texas. Last edited by roger1; 01-09-2008 at 06:49 PM. Reason: Spelling |
Sounds good.We have to deal with those a** Holes.
Good thoughts. Thanks.
#1. Not too concerned with heating here in San Angelo, TX. The winters are pretty mild. Matter of fact it is 78 degrees right now. I will be putting in A/C for the summer. I think I will build in a couple of heat/cool units. One for the main area and one for the clean room. #2 As far as getting a permit in San Angelo, I just have to make them believe it is not going to be for living space. #3 I have given this a lot of thought and decided if I ever get a lift it would be one of those low units that can be disassembled and moved out of the way. Don't need a high ceiling for one of those. I have a house attached 2 car garage already so I have enough vehicle storage. Quote:
Where did you see that old gas station ? that's cool!!!
Here's the link: Ambler's Texaco Here's a drawing of another actual gas station in Gonzales, TX that I think is really cool. At first I thought about using this style, but I really didn't want to go with a flat roof.
Already have checked with the city. My total out-building square footage can be 1/2 of the square footage of the main house including the attached garage. So, I have no problem there. Yes, my lot is 4.1 acres. |
| Recent Garage - Tools posts with photos |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| Maiting calls of the garage | Halloweenking | Hotrodders' Lounge | 22 | 09-19-2006 09:18 PM |
| Garage Safety | Kevin45 | Garage - Tools | 48 | 11-26-2005 08:49 PM |
| Hotrodders Knowledge Base: Garage - Tools | Jon | Garage - Tools | 0 | 11-26-2005 06:46 PM |
| Some more ideas for the garage | Kevin45 | Garage - Tools | 7 | 01-28-2004 11:36 AM |
