Designs for building a 700ish HP 383 stroker - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-16-2010, 09:38 PM
ericnova72's Avatar
More for Less Racer
Originally Posted by dbmx66
for those of you who dont believe cam383aro, i have seen a naturally aspirated 383 stroker run a car into the high 8s, its all aluminum dart block, cnc ported dart heads, .650 solid roller cam, cnc ported dart intake, ect. its pushing 15:1 comp, its a 93 firebird with a tube chassis, 4-link rear, full fiberglass body, narrowed dana 60 with 5.-- (forget the exact number) spooled rear with 32x14 inch goodyear eagle slicks. anything else you wanna know let ask me
I don't doubt you because I know it too - specs like that and light weight body will get you there.....it isn't really cheap tho', and I wouldn't even remotely call it street friendly, any street friendly body is just going to slow it down and it will eat up valvesprings. $25 a gallon fuel to run that 15-1 is pretty salty $$$ to just cruise on also.
Doing it with a Factory block is pretty risky , how does your luck run??
An awful lot will get sacrificed if the block gives up.
  #32 (permalink)
Old 02-16-2010, 09:39 PM
and as i said in the first post I will buy another block if thats the better way to go!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
  #33 (permalink)
Old 02-16-2010, 09:47 PM
and i know i'm not gonna get those numbers when dropping it in to a dead weight camaro, and im not gonna do everything that he did to his car...
  #34 (permalink)
Old 02-16-2010, 09:50 PM
ericnova72's Avatar
More for Less Racer
Outline the vehicle it will go into, its weight, fuel, your performance goals and your budget, then we can start to fill in the blanks.
  #35 (permalink)
Old 02-16-2010, 10:01 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You also said in your original post that you want a lot of torque as well. That is yet another reason to consider a big block. A 700hp 496 is going to make a lot more torque than a 700hp 383 will.
  #36 (permalink)
Old 02-16-2010, 10:17 PM
what do you have in mind for a big block, I havent really delt much with them
  #37 (permalink)
Old 02-16-2010, 10:19 PM
techinspector1's Avatar
Wiki Edits: 326
Yep, and a 632 will do it even easier.
That engine is #1 on my bucket list to do before I cash in....
  #38 (permalink)
Old 02-16-2010, 10:23 PM
Blazin72's Avatar
Wiki Edits: 19
I've never built one either. I just know that if I were to shoot for that kind of power I'd start with a big block. Probably a 496, maybe bigger.
Techinspector, I like your thinking. Can we put a supercharger on it too?
Anybody remember Hot Rods 632" Crusher Camaro? 750hp at 5800 rpm. 750 lb-ft at 4800 rpm. Cam383aro there's your torque.
http://www.hotrod.com/techarticles/e...ine/index.html
  #39 (permalink)
Old 02-16-2010, 10:26 PM
haha i would love to put a supercharged 632 in but thats way beyond what i'm trying to build... Anyone else have a suggestion about big blocks??
  #40 (permalink)
Old 02-17-2010, 03:10 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
here is a calculator I wrote. the preset fields are for an old friends 496. it was a stock 2 bolt production block and not filled. The heads were AFR 345's.
http://www.speedwaybids.com/camshaft_calculator.html
it would RUN on pump gas but not race. In a 3200 lb chevy luv with a large dose of nitrous it went 8.70's. With the same basic combo but with a brodix 2 plus heads and a 730" / 282 @ 050 cam it dyno'ed at 730 HP and eventually went 9.1x's
http://www.streetfire.net/video/Chev...rst_123428.htm
IF you are dead set on a 383 stock block fill it and pray.
14.5 compression, AFR 235 cnc eliminator's (322/231) a cam with 274-277 @ 050 / 630"-650" .... should net the 700 + HP
  #41 (permalink)
Old 02-17-2010, 06:49 AM
Banned
Originally Posted by 68NovaSS
In a word, yes. That's what we do, and there's no argument that what you posted was sarcasm and degrading. You call it censoring, I call it editing.
Is there some place I can petition for a moderator to be removed? "Editing" for personal reasons is perhaps the worst form of censorship.
  #42 (permalink)
Old 02-17-2010, 08:49 AM
Build a 421 since you have to buy a dart block anyway, 14 to 1 squeeze, solid roller mid 250's duration at .050 around .650 lift.AFR 220 heads, 800 or better carb will put around 650hp give or take a few.Will pull like a freight train from 3000 up to 7200.106 lobe seperation installed at 102 degrees.
  #43 (permalink)
Old 02-17-2010, 09:12 AM
Banned
At this power level the cost between big block and small block is less than you'd think, hell a big block build may end up being cheaper. If you want a streetable 700hp I'd start with at least a 502.
OR run a hose to it or blow on it real hard.
  #44 (permalink)
Old 02-17-2010, 09:23 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
and btw it doesnt run 8s everyday. its usually a very low 9 second car
no one ever said it wasn't possible, but that it was next to impossible with a stock block, and you have just proven the point that i tried to make earlier, that he just didn't know everything that his buddy had into his car.
i would personaly recomend a BBC as well, and since you want 700ish hp then you will need to go with a forged rotating assembly so why not go with a 489 or 496, one is .030 and the other is .060 (this will probably be the easiest stroker to make) i've seen 700hp run on a stock gm big block, but it will need clearenceing just like the 383 would, you will need to have a 454 block machined then get a 4.250 crank. it would be far easier to get the hp/tq number you are looking for, and possibly be able to run it on the street. now it would be safer to run a after market block like the DART big M for this but if you were to go that route i wouldn't shoot for the 489/496 i would have the bore cut to 4.500 and run either a 4.250 crank (540) or a 4.500 crank (572) it would cost a little more but the numbers you want to reach would be easy with these CID's and you could do it easily on pump gas you would also be able to match you tq to your hp like 700hp/700tq
  #45 (permalink)
Old 02-17-2010, 08:22 PM
Landshark928's Avatar
FrankenPorsche
With out a power adder, your daily street driving will stink @700hp. Nitrous is nice since you only use it when needed. Driving a high HP car on the track is one thing. Trying to control it on twisting roads when a deer jumps out is a whole nother story. Nitrous lets you keep things sane for getting groceries but still be insane on track day. Plus nitrous can travel to your next car.
IMO Build a strong 450HP 383 with forged internals. Then hit it with the giggle gas. It'll cost 1/2 or less of a NA engine making the same power.
383 Stroker chevy101 Engine 3 11-23-2009 08:03 PM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 11:05 AM
SB Chevy Balanced 383 Stroker Kit from CNC-Motorsports.com bccsrc Engine 19 01-04-2006 06:51 AM
hp of a 383 stroker mathjew Hotrodding Basics 5 11-02-2004 10:14 PM
