Designs for building a 700ish HP 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2010, 11:36 AM
I'm looking into building a 383 stroker soon, I already have a 350 bored 30 over, might use that or else summit sells a 383 block for $729.99, I want this motor to snap and am looking for alot of torque as well. Any opinions on compression ratios, heads block, crank... basically a good blue print on everything haha... I have built up a few 350s before so I'm not new to the process but I haven't built a 383 yet... I am not gonna cut corners on this project as that has bit me in the *** to many times...
Pat
Old 02-16-2010, 12:04 PM
How fast is fast enough?
you can't run 700hp out of a factory block, or atleast long enough to win any race. And at the 700hp level you're lookin at a few rebuilds each season.
Old 02-16-2010, 12:21 PM
I'm aware of that and I am planning on doing the modifications to allow for that much power, i am looking for a simple blue print from anyone who has done it before.
Old 02-16-2010, 12:33 PM
you can't modify a oem block into a race block.
Old 02-16-2010, 12:40 PM
327NUT's Avatar
There is no such thing as a general "simple blueprint", there are the normal things that have to be done on a very high performance build but I dont think you got the gist of what ap72 was stating.
A stock production block won't last very long at 700hp, you will need an aftermarket block and the best forged reciprocating assembly you can buy. The cup cars run about 800 hp and they cost moooocho $$$$$$$$$$$$ because EVERTHING is aftermarket.
Old 02-16-2010, 12:42 PM
thats funny cause I am friends with 2 people who have been racing for near 30 years and run 383s that they pulled out of late 60s and early 70s vehicles and modified them and are putting out more than I am looking for (running 8s ) and btw this is street and strip
Old 02-16-2010, 12:46 PM
yes, i understand that there is a lot of work involved but I am friends with really good machinists who will do it for me for no charge... and i no there is a lot of money involved, I am willing to pay big bucks to build this motor, I'm not gonna be beating on it constantly, i no there is no simple blue print as well im asking as for the lower end and heads and cams give me something that has worked for you, to start with...
Old 02-16-2010, 12:53 PM
Running 8's in what and where at?
If they are running in a production car with an OEM 350 block they are NOT running 8's, unless you're talking the 1/8 mile.
And NO amount of machine work can make an OEM block a true race block.
Old 02-16-2010, 12:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
When it comes to questions like this I always to go my default answer: Supercharge it.
Or get a 454 and build a 496.
Old 02-16-2010, 01:43 PM
first, high 8s at Maple Grove Raceway, Mohnton Pennsylvania is where I watch him race at and its in a trans am funny car, NOT RUNNING ON ALCOHOL OR ANYTHING LIKE THAT, 15:1 compression ratio, no nitrous or supercharger... and yes its in the quarter mile, and it looks like oem blocks are racing all over the place.
Also I was considering super chargin but would rather just go with a big compression ratio
Old 02-16-2010, 01:49 PM
If you think someone is running a 15:1 funny car into the 8's NA on gas on an OEM block **************.
Old 02-16-2010, 01:55 PM
powerglide tranny, tube chassis, full fiberglass body, lexan windows, 4 link rear weighs just over 2grand... it runs high 8s
Old 02-16-2010, 02:03 PM
I could believe most of that, the biggest thing is 15:1 not on "alcohol or anything like that."
Old 02-16-2010, 02:06 PM
i no the car... its as i said it was, i'd send you a youtube link to it but the owner is a foreman of a garage and not on a sponsored team so there are no videos of it that i could find online
Old 02-16-2010, 02:40 PM
68NovaSS's Avatar
Wiki Edits: 9
Sarcasm and criticism removed, no technical merit.
383 Stroker chevy101 Engine 3 11-23-2009 08:03 PM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 11:05 AM
SB Chevy Balanced 383 Stroker Kit from CNC-Motorsports.com bccsrc Engine 19 01-04-2006 06:51 AM
hp of a 383 stroker mathjew Hotrodding Basics 5 11-02-2004 10:14 PM
