Desk top dyno question please - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2003, 11:17 PM
Jmark's Avatar
Guess its my turn for a question here.
Started putting together my sons 400 tonight and we're wondering what it might end up putting out. Here's the specs.
.030over 400
stock 400 crank
350, 5.7 rods
Keith Black hypers 9.1 comp ratio
Pro topline heads:
200cc intake runners
64cc chambers
2.02, 1.60 valves
quinch set to .045
Camshaft, Comp roller:
Intake duration, 230@.050
Exhaust duration 236@.050
Advertised duration, 282@.006
Lift, .510 both valves
Seperation 110
Comp roller lifters
Crane roller rockers
Intake: Edelbrock performer
carb: modified q-jet 750
Stock HEI dist
Modified Turbo 400, stock converter
411 gears.
Old 10-10-2003, 06:16 AM
Wrencher's Avatar
Jmark, 396h@5500, 418t@4500, w/ mufflers!
Old 10-10-2003, 11:21 AM
Jmark's Avatar
Wrencher,, thanks for the reply, we appreciate it. My son was hoping for more hp, but its basically just a really high dollar slightly over stock engine. Should run good though.
Mark
Old 10-10-2003, 11:32 AM
Wrencher's Avatar
10-1 would put ya at 414@5500. 437 w/o muffler
Old 10-10-2003, 12:23 PM
Jmark's Avatar
the machine shop is real concerned on pinging here in PHx. It gets really HOT here in the summers. Plus, we don't want to have to run premium if we can help it.
I"ll be getting my 350 going as soon as the 400 is done. Would you mind running my numbers for me? If you can, thanks.
.030 over 350
stock stroke and rods
Speedpro coated hypers, 9.0 cr
Quinch set @.045 ( hopefully)
Heads are cast chevy '882, '76cc 1.94, 1.5 stainless
runner cc unknown
Crane cam, hyd ( non-roller)
216@.05 both lobes
adv dur. 272
seperation 110
gross lift .454
Crane full roller rockers
Edelbrock performer intake and 750 q-jet
stock HEI with Crane coil
350 auto, 3.41 gears. ( yuk!!)
Old 10-10-2003, 07:23 PM
Jmark's Avatar
bump
Old 10-13-2003, 06:47 AM
Wrencher's Avatar
Sorry Jmark! Ihaven't been on since fri.! Here's the 350 #s, 344h@5500, 383t@4000
