desktop dyno please - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2005, 04:16 PM
desktop dyno please
350 small block chevy bored .030 over=355
first with a melling mtc-1 camshaft,
then a comp cams xtreme energy 268 camshaft,12-235-2 Comp Cam. Here are the specs: 210/218 at .050" and .447/.462 lift with a 110 LSA and a 106 centerline.
9:1 compression
650 cfm edelbrock performer carb
edelbrock performer intake
i am wanting the motor to be for low-end torque, please desktop dyno it,
also if you have any suggestions for the camshaft, (i was told by a comp-cams tech on another forum that, that cam was the best for low-end torque )
Old 08-11-2005, 05:26 PM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
Yes, that cam will do you nicely.
Old 08-11-2005, 09:56 PM
larryblack's Avatar
Certified Lead Foot
I used much the same profile from comp, crane and sig erson to build torque motors for daily drivers and pick ups.
I also liked to use the 4* advance key on the crank timing sprocket. By advancing the cam you will increase low speed performance and not really bother overall performance. A side benefit is usually higher vacuum which makes tuning easier.
I usually could get solid power to 5500 rpm from the engines if I pushed them.
If your screen name reflects the vehicle it is going into, you will like the smooth power your combination should make.
Old 08-11-2005, 10:05 PM
Jacks 1977 Corvette
How about a dyno on mine?
My motors specs are:
Balanced & Blueprinted 350 bored .030 over
w/ TRW Forged Crank
TRW Forged Flat Top 10.1 Pistons; Moly Rings
Racer Brown Cam 480 lift; Red 1.5 Roller Rockers; Heads ported/polished
BG Speed Demon 750cfm w/Edelbrock Manifold Performer
Hooker Super Competition Sidemount headers into 4" collector
125 Hp NOS
TH350 3spd auto w/2,400 stall and B&M shift kit, 3:73 gears
desktop dyno 2000 = are they truthful 406 ss monte Engine 24 07-25-2005 06:57 AM
desktop dyno again please 82c10 Engine 8 07-24-2005 09:48 PM
Need some help with desktop dyno. Novaman78 Hotrodders' Lounge 3 10-15-2004 09:55 AM
Desktop Dyno 2000 Head & Cam Profiles Silver_Camaro General Rodding Tech 2 09-28-2004 01:42 PM
Please desktop dyno this 454 wo/aftermkt heads that ran a 13.1 on its 2nd 1/4 ever elukas Engine 7 01-03-2004 01:24 PM
