DeSoto 341. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2012, 09:03 AM
ewoky409
DeSoto 341.
Does anybody know where I can get the specs for this 57 DeSoto 341 hemi?The engine stamp is S25-4T62I.Thanks.
Old 02-04-2012, 09:50 AM
RWENUTS's Avatar
Google 1957 desoto 341 hemi specs and choose your poison. Here's one that came up.
http://www.classichemi.com/index1.shtml
Old 02-04-2012, 10:00 AM
2x4`s can help
Hi ewoky409
I think I have what you need guy.
Bore&Stroke 3 25/32 x 3 51/64 cid 341.4
AMA Horsepower 45.7, 270@4600
Torque 350@2400
Compression 9.25
Valve Lifters Hydraulic,Lash 0
Oil pressure 50 psi at 30mph
Tune up Numbers
Spark plug Gap .035
Point gap .015-.018
Ignition timing 6 B
Fuel pump pressure 6 1/2
Idle speed 500
Cranking compression 160 psi
Condenser .25-.28 microfarads
Dist. dwell 26-28
Firing order 18436572
Left bank front to rear 1-3-5-7
Right bank front to rear 2-4-6-8
May I wish you the best of luck with your "Fire Dome"
I LOVE DeSoto`s
2x4`s
32 desoto 60 grit Suspension - Brakes - Steering 7 05-15-2011 04:53 AM
49 DeSoto camelot Introduce Yourself 3 01-22-2011 07:31 PM
291 DeSoto Help 345 desoto Engine 2 08-14-2008 09:26 PM
Desoto Man terrydrace Introduce Yourself 7 03-05-2007 08:02 PM
DeSoto Rat Rod DeStang Hotrodders' Lounge 19 12-05-2006 11:31 PM
