desoto firedome 331 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2009, 10:42 AM
desoto firedome 331
engine is getting gas, will turnover, but will not fire. What troubleshooting should i try to get it running?
Old 06-24-2009, 12:35 PM
Don't mean to be a SA, but have you checked for spark? What sort of reaction ARE you getting? Does it just turn over, without any popping, or kick at all? If you're getting NO reaction, and the motor turns over and there is sufficient fuel, you might not be getting any ignition at all.
Pat
Old 06-24-2009, 05:58 PM
Wiki Edits: 49
A little more info would be helpful. Is this a recent rebuild?? Are you using the original distributor or have you switched to an electronic distributor??
It sure sounds like you're not getting any spark.
Old 06-24-2009, 07:43 PM
techinspector1's Avatar
Wiki Edits: 326
Tom, I don't mean to be a SA either, but I don't think DeSoto ever made a 331. That was a Chrysler size. DeSotos came in 276, 291, 330, 341 and 345 to the best of my knowledge.
desoto engine swap dmented Engine 15 12-15-2014 04:46 PM
DeSoto Intake Interchange 345 desoto Engine 3 01-07-2009 10:05 AM
Hypereutectic Pistons for a 331 coda618 Engine 6 04-08-2008 02:41 AM
Searching for Early Hemi Engine info racecop53 Engine 10 12-29-2006 07:19 PM
331 marine industrial LilSmoke Engine 3 08-24-2004 07:31 AM
