Desoto flathead 6 sitting for 15 years - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 06:25 PM
67Elcamino's Avatar
Im tempted to try to get my 1940 Desoto flathead 6 started. As far as the previous owned mentioned, it has been sitting for about 15 years an ran fine before that. It turns freely therefore doesnt seem to be frozen. Its a 6 volt systems. The car is all original.
Before I charge the battery and attempt to start what should I do?
I already cleaned out the gas tank. Should I oil the cylinders manually turn a few times? what other things should I do before doing so? I'm interested in any suggestions regarding the cooling system etc...
How do you charge a 6 volt battery anyways? Im sorry if these questions seem lame but Im not familiar with Flatheads and 6 volts systems
Old 09-01-2012, 07:12 PM
Cape Cod Bob's Avatar
AACA Forums
Old 09-04-2012, 12:27 AM
fstfish66's Avatar
mopar or no car
the guys on the P15 D 24 site will be glad to help you with this,,
but i would pull the plugs oil all the cylinders,turn the motor over by hand, oil the cylinders again,,,change the engine oil,and filter if it has one,, new plugs,,,new points,,and a new 6 volt battery for now ,,later u can look in to switching over to 8 volt or 12 volt,,your starter may not like 12 volt give her a whirl,,, like i said the guys on the P15 D 24 site have a ton of answers for flat heads,,or check the hamb,,,
Old 09-04-2012, 08:37 PM
KMyA
As far a charging a six volt battery just get a battery charger that charges either six or twelve volts via a selector switch.
If the carb is gummed up be prepared to take it apart and clean.
bt
Cadillac has been sitting 30+ years blyndgesser Hotrodding Basics 11 12-21-2011 06:47 PM
Engine has been sitting for 4 years spacytracy Engine 6 11-16-2010 08:18 AM
No compresion after sitting for 2 years maddogmodl Engine 15 06-18-2009 04:48 PM
Sitting for roughly 20 years jrm123180 Engine 48 04-04-2007 06:56 PM
383 been sitting for almost 6 years Bryce Engine 9 05-14-2005 05:14 PM
