desoto question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2010, 08:09 AM
desoto question?
will a 53 desoto steering wheel fit on a 54 column. need to know before i buy. help!!!!!
Old 12-17-2010, 03:35 PM
35terraplane's Avatar
desoto
Can you count the teeth on each, and check the diameter, Check and see if they have a flat space between two teeth and check size, I would guess that they would fit, but would measure first.
35terraplane.
Old 12-18-2010, 07:27 AM
thanks, that was helpful
Old 12-18-2010, 09:03 AM
Wiki Edits: 27
catalog cross ref.
I used to keep a few catalogs and check to see what parts fit what cars, The old J C Whitney catalogs listed steering wheel adaptor kits , check part numbers and you were 90% likeley to have it work.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Fuel System question Ratoflic Engine 5 01-23-2010 11:04 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
