destroyed 1 torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2005, 12:13 PM
remember me? 700r4 wont go? new trans shop says one valve was in backwards but real problem was torque converted was not seated and self destructed - so I looking for tips on installing torque converter-just read another question re seating the torque converter but it really didnt say how to make sure the converter was all the way in and completely seated - the trans shop said that was the real problem - any tips will be appreciated - expensive lesson!
Old 04-16-2005, 12:52 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
covertor
I put some fluid in the convertor for lubrication. A little vaseline on the neck for seal lubrication. I install the convertor with the two cuts in the neck aimed out to the sides. Not up and down. They can dig into the bearing and score it. I wiggle the convertor into place. Then I spin it until I hear it lock 3 times. Each time it clicks it should move into the tranny a little further. When it spins without going any further in tranny it's set into place. When you bolt tranny to the motor make sure you have about 3/8" clearance between convertor and ring gear. Bolt it to ring gear.
Old 04-16-2005, 05:17 PM
thanks for the advice - I'll get tranny back on monday and install next week - I'll post my results - thanks - hot rod john
Old 04-17-2005, 12:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
follow what bracketeer says...
there may be less than 3/8 space between the converter & flexplate when both are bolted together.
the converter MUST spin freely as you bolt the tranny to the engine. IF it binds up, pull the tranny back to check the converter install into the tranny !
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 07:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 12:08 PM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 03:57 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 09:27 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 06:21 AM
