To detail gun or not to detail gun? Jamb spraying - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 12:18 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I know we all sick of the damn gun posts As some of you know im going to start a paint job on my Bronco soon, Im doing some spot repairs in the rockers and want respray the jambs first before the body. I dont mind spending some $$ on good quality tools, im looking at the Startingline detail gun with a 1.0 tip for 60.00 shipped. Is it worth it VS using a standard gun? I shoot now with a finishline 3 and have had great results with it doing primer, base and clear with the different included tips (1.3-1.5-1.8). This 1.0 tip is what im concerned about, since ill just be doing the jambs with the detail gun will the 1.0 tip work well enough with all three coatings??
I could just use my FL3, but feel the detail gun will save on overspray and materials...
Just thought of this, will my fluid tips from the FL3 work on the detail gun??
Old 07-04-2012, 01:04 PM
Mach1460's Avatar
Another thing I was thinking about is it might be easier for me to pull the doors. Then I can mask the interior off, spray the jambs at the same time I do the body because its a two tone paint scheme. Tan/mocha bottom with black above. Ill spray the doors at the same time just not on the vehicle..
Old 07-04-2012, 01:13 PM
mitmaks's Avatar
Last journal entry: Grille
I'd go with this idea.
Old 07-06-2012, 05:36 AM
deadbodyman's Avatar
Wiki Edits: 11
With the doors on I would use the detail gun ...doors off, regular gun...
Old 07-06-2012, 07:58 AM
cyclopsblown34's Avatar
Colorsanding painter
I agree with this feller!
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
Cleaning Gun After Spraying SHIFTY101EASY Body - Exterior 13 06-14-2007 04:37 AM
HF detail gun worth trying? Brian_B Body - Exterior 11 06-08-2007 01:12 PM
