Detecting stall speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2008, 03:15 PM
Marcel
Last journal entry: Choo-choo town
Is there anyway to find what the stall speed of a converter is without removing it? thanks
Old 02-04-2008, 03:24 PM
life is a temporary assignment
You can hold your foot on the brake in rev it up till it start's to pull,This will give you a idea were it's at.If you have a tach.
Old 02-09-2008, 12:48 AM
Set up a data acquisition system to log RPM and look at the slope of the graph
Look at the blue line. This one stalled at about 4000rpm after staging at about 3000rpm.
stall speed speed_demon666 Engine 2 11-16-2007 07:21 AM
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
Stall Speed trees Transmission - Rearend 6 04-13-2003 06:59 PM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 08:59 AM
