detent cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2008, 04:24 PM
detent cable?
Is a detent cable another term for transmission kickdown cable??
Old 12-15-2008, 04:26 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Yes they have also been called TV cables depending on the application.
Old 12-15-2008, 06:06 PM
302 Z28's Avatar
A detent cable and a kick down cable is not the same thing as a TV cable. A TV cable has a completely different purpose than a detent or kick down cable. The TV cable directly controls transmission pressures in 700R4 and 4L60 GM overdrives..
Vince
Old 12-15-2008, 06:39 PM
My point is they have all been called the same thing, kick down cable is used a lot when people dont know what to call it. They know if its not working the tranny wont down shift. "kickdown"
Old 12-15-2008, 08:01 PM
302 Z28's Avatar
If the TV cable is not working right there will be far more serious problems with the tranny than "kickdown". An improperly adjusted TV cable can "fry" a trans in very short order. My point was to mention "kickdown cable", and "detent cable" in the same sentence as "TV" cable as they are all the same is not correct.
Vince
Old 12-15-2008, 09:26 PM
life is a temporary assignment
The TV stands for (Throttle Valve) Dentent cable controls line pressure.Here's a web site that tell's you a little about it....Like Vince said if it isn't set right it will fry your transmission...
http://www.thirdgen.org/detent
Old 12-16-2008, 12:19 AM
Dont forget about the 200-4R it has the Throttle Valve cable too.
Vince
Old 12-16-2008, 04:20 AM
What kind of car do you have?
Old 12-16-2008, 05:40 PM
A 1980 z28 with a TH350. Don't believe these have a TV cable
Old 12-16-2008, 06:19 PM
Everyone I found have been called kickdown cable.
Is your not working?
Old 12-16-2008, 06:26 PM
It's not there lol.
Old 12-16-2008, 06:32 PM
Well then its probably not working lol
http://www.jegs.com/webapp/wcs/store...%2Bmatchallany
Wow thats one big link
Old 12-17-2008, 07:38 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
lokare (spelling) has a better part , closer to factory with a much simpler adjustment, again factory design.
the down side , is that you must or it comes with if you like the term better, with there carb throttle cable assembly, no way to buy the parts separately...
Old 12-17-2008, 09:13 AM
302 Z28's Avatar
Correct, the only GM transmissions that have TV cable are the 200R4, 700R4, and the 4L60. The TH350 and TH400 are kickdown or detent cables.
Vince
Old 12-17-2008, 09:34 AM
So without the detent cable in place my TH350 leaks out transmission fluid out of the hole where the cable attaches to the rod like a stuck pig. Should this be expected??
Detent cable question RObs71Nova Transmission - Rearend 9 12-13-2004 10:45 PM
stuck detent (kickdown cable) dawg Transmission - Rearend 2 09-20-2004 09:58 AM
