detent pressure spring ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2007, 07:34 AM
6426yy's Avatar
Just a quick question. I did a search with no avail.
When I rebuild my TH350 the detent pressure spring was busted, it was orange in color. So I replaced it with the one in the old 350C which was yellow and seemed to be quite a bit stiffer.
What difference would this make if any? The trans is working great so far, I was just curious as to what this change would do.
Thanks
Old 01-07-2007, 08:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
If it works , must be OK.
I am curious on how you discovered it was broken? Were you installing a valve body recalibration kit?
Old 01-08-2007, 09:37 AM
6426yy's Avatar
Thanks Crosley,
When I rebuilt the trans I disassembled the valve-body to clean it. It may have snapped when I removed it as it hung up on the retaining pin. But either way it was rather flimsy compared to the one out of the 350C.
Old 01-09-2007, 12:39 AM
valve body kits
Thanks
the heavier spring will regulate higher detent regulator valve pressure, which will let you get detent 3-1 and 3-2 at higher speeds.
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
No Oil Pressure!! MartyMart9@aol.com Engine 43 04-26-2005 06:37 AM
Rocker to Spring Clearance AFR Springs DTL504 Engine 2 06-02-2004 12:38 PM
Low oil pressure fred56 Engine 4 10-08-2003 02:19 PM
Proper throttle spring placement willys36@aol.com Engine 1 11-13-2002 07:19 PM
