detergent oil or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 07:27 PM
If you have and older engine (smokes a little) and previous owner used non-detergent oil,Is it advisable to switch to a detergent type oil?
Old 09-01-2010, 07:44 PM
Cape Cod Bob's Avatar
For A high mileage motor that would not be advisable. The detergent oil will clean out the junk that has built up over time and may loosen up things to cause you to use more oil or make things noisey. At least that is what I was taught. .
If it smokes a little it may smoke even more.
Pop off the valve covers and be sure the return holes are open to let the oil back down to the pan.
Old 09-01-2010, 07:52 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Ditto, to what Cap-Cod Bob said.
Rich
Old 09-01-2010, 08:03 PM
techinspector1's Avatar
Wiki Edits: 326
And another ditto from me.
Old 09-01-2010, 08:57 PM
LATECH's Avatar
when does it smoke ? on deceleration? when you stomp down on the gas? it might be wise to determine (if you can) why it smokes.if it smokes only on deceleration it is most likely valve guides or seals, if it smokes all the time and especially when accelerating then it is probably rings. pull the pcv valve from the valve cover with the engine running , if it smokes like the little train that could, then it is rings. Valve guide seals can be straightened out without pulling the heads, just use the umbrella type seals. If it is determined to be rings.... keep running the non detergent
Rings can become stuck in the piston lands by not using a detergent oil, but in your case being a high mileage engine I doubt that is the case
Old 09-01-2010, 08:58 PM
Older motor---no PCV valve
Old 09-01-2010, 09:00 PM
LATECH's Avatar
downdraft tube?
Old 09-01-2010, 09:02 PM
Originally Posted by latech
downdraft tube?
Yep,thats what it has
LATECH's Avatar
is it smokin pretty good outta the tube?
Old 09-01-2010, 09:04 PM
smokes little from tube and little at exaust,but runs strong!
Old 09-01-2010, 09:08 PM
LATECH's Avatar
yeah sounds like rings are kinda worn. detergent would not be good idea.like the guys were saying it will probably remove the crud thats in between the rings that is keeping it from smoking like a freight train . LOL
Old 09-01-2010, 09:09 PM
LATECH's Avatar
too bad it is not guide seals that is an easy fix
Old 09-01-2010, 09:30 PM
Well,thanks for the advice----will stick with non-detergent----Unless I ever rebuild it---but thats another story
Welch Plug - In or Out? Gun Laker Engine 5 11-03-2009 08:50 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
oil suggestions and preferences timemachine Engine 2 05-07-2008 03:07 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 06:26 PM
Oil Change THX_138 Hotrodders' Lounge 25 12-20-2006 04:01 PM
