determine hp on 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2011, 04:58 AM
hi i have a 350 4bolt wit 11 to 1 comp victor jr heads an comp cam solid roller cam spec gross valve lift .631 .631 tappet lift intake 286 exhaust 290 108 cnterline duration .050 intake 250 exhaust 254 lobe lift .4210 .4210 lobe seperation 108.0 with a summit 750 4barral i hope this is enough infomation
Old 05-25-2011, 06:51 PM
350 Sbc Hp
We just finished dynoing a 358 inch SBC 10.2 CR, with 170cc RHS heads, solid flat tappet, 750 carb. Everything in you engine is a step up from ours. Ours made 437 HP @ 6200. I'd guess yours to be 525-550 HP @ 6500.
Ron
1974 Chevy C-10 how to Determine rear gear. Tbone714 Transmission - Rearend 6 04-10-2009 11:36 PM
how do you determine anokha Engine 6 05-21-2008 01:17 PM
How can I determine if? barnym17 Body - Exterior 8 05-10-2008 07:56 PM
Need to determine a car denk General Rodding Tech 1 12-15-2003 03:44 PM
How do I determine the CID of Chevy Engines dmg53 Engine 4 03-03-2003 08:06 PM
