Determining CG height: An easier way - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 05:39 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
I've added a page (Page 39) which provides a relatively painless method for determining center of gravity height. No wheel scales or jacks are needed.
http://www.racetec.cc/shope
Old 06-27-2009, 07:23 AM
BillyShope's Avatar
Philippines Cowboy
I've added 7 paragraphs to clarify use of the spreadsheet. The intent was to go beyond the "engine camshaft height is the same as the car's CG height" method, but some have interpreted the spreadsheet input to require very exact weights and measurements. Hopefully, these extra paragraphs will return the spreadsheet to its intended "easy" application.
This beginner finds B/C easier than SS BIGSKY Body - Exterior 6 09-07-2007 10:18 PM
setting ride height for suspension swap pigmechanic Hotrodding Basics 3 12-21-2006 10:25 PM
installed height question 19nova72 Engine 8 07-05-2005 09:23 PM
vortec heads, quench height revisited blndweasel Engine 6 07-20-2003 06:45 AM
valve spring installed height? Kramer Engine 5 05-16-2003 04:36 PM
