Determining a decent ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2007, 08:48 PM
junkyardjeff's Avatar
I am putting a new driveline in my 37 chevy p/u,I am retaining the 235 but installing a S10 5 speed and modern rear end. The 5 speed has a 4 to 1 first gear and in 5th the output shaft turns 1 1/3 to one revolution of the input shaft so it looks like there is not much overdrive,I was wanting to use 3.73 gears but with the 4 to 1 first gear it looks like a little taller gear will be needed. It has 235/75 tires on the rear so would a 3.25 to 3.55 gears be a decent choice for what I have. Jeff
Old 11-19-2007, 09:15 PM
Wiki Edits: 31
S10 T5 trans likely has a .72 ratio, but may have a .83 or .85 if your lucky, but these were more common pre 1985.
judging by the project 33 calculator, you'll be turning 1,725 RPM at 65 MPH in 5th. 2,549 RPM in 11st going 20 MPH.. with a 3.73
I'd say 3.73 would be a good choice but heres the calcs anyway http://www.project33.com/tiresize.cfm#trans_rpm
Old 11-19-2007, 10:37 PM
70 ElCam's Avatar
Rebel with a Chevy
You're going in the right direction with the 3:73s, as stated in the previous response. The question is if the 235 will pull the O.D. when combined with anything higher than that with the 235/75s you'll be running. As I recall mine liked to keep a little rev on it to pull hills good .
Nice calculator matt .
Old 11-20-2007, 04:12 PM
The only concern I have is with the 4 to 1 first gear in the 5 speed,I dont want first to be like a granny gear with the 3.73 gears. Jeff
Old 11-20-2007, 06:33 PM
31 five window
Last journal entry: Moving along with patch panels.
Go with 3.73 and if first is too low drive it like the old granny gear and take off in second.This will be like having an under and over drive for if ever you really need to pull or climb a steep hill.
Old 11-21-2007, 07:56 PM
need strog32 chevy front doors
Last journal entry: LittleFloor
How much should i expect to pay for for that S10 5 speed. I a looking into it for my 32 chevy 3:73 rear end and 250 chevy engine . What year too
Old 11-21-2007, 08:44 PM
shortyforty's Avatar
Last journal entry: V8 suspension added
Here is a Excel speed calculator freeware I found that lets you play with a number of factors. Includes graphs of results.
Don't know if this link to it will work to download and save from.
http://www.newmotherearth.com/Misc/SpeedCalculator.xls
Old 11-21-2007, 09:26 PM
I got my 5 speed for 75 dollars and I think there are three trans with different ratio spreads,the trans I have has a 4 to 1 first gear which might act like a granny gear with a steep gear. I am leaning towards a 3.55 gear for my truck instead of 3.73s then I woint need 5th around town. I have seen them priced all over the place so shop around. Jeff
Dynamic Compression Ratio?? starnest Engine 3 04-27-2007 02:22 PM
Proposal: 9/11 is Be A Decent Human Being Day FrankR Hotrodders' Lounge 1 09-03-2005 05:37 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
determining compression ratio JH30906 Engine 1 07-08-2003 03:05 AM
Determining gear ratio on an "OPEN-differential, GM 10-bolt NASCAR314 Transmission - Rearend 6 11-07-2002 08:25 PM
