Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - detonation
Thread: detonation
Old 08-13-2002, 05:46 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
You should be able to make the advance plate at least move with mouth suction but.....the best way to check is with a suction pump because you need to check for slow leaks by maintaining a constant fixed vacuum and see if the diaphram holds the vacuum. I have been able to generate 18 inches of mercury by the the oral method if you use your tongue to block the hose during sucks....
I detect the possibility of this conversation degrading with all this sucking and turning purple and such so I will just back away from the subject carefully. <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
— Han Solo
