detonation - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-13-2002, 06:51 AM
lamothe1's Avatar
Post
one more thing. I've been told that a non-functioning EGR valve can cause an engine to ping. maybe the guy you bought the truck from disconnected it. <img src="graemlins/nono.gif" border="0" alt="[nono]" />
  #17 (permalink)
Old 08-13-2002, 07:55 AM
Arrow
Just a thought here, but.... you never stated if this was a new crate motor or a rebuild!!! Always, always check timing. It is possible to have the timing marks slip out of position or a balancer put in wrong! get it to run at its best by tuning by ear and see what happens then...
  #18 (permalink)
Old 08-13-2002, 01:31 PM
Post
You answered your own problem - If you can suck on the vac advance by mouth or Vac pump and nothing happens and you can keep on sucking and still nothing - The Vac Advance is NO GOOD,Broke,Busted - Replace it - You should be able to hold a Vac in the chamber. <img src="graemlins/drool.gif" border="0" alt="[drool]" />
  #19 (permalink)
Old 08-13-2002, 04:48 PM
New Member
Post
Didn't know this topic was gonna cause so much response. The engine is a 350 rebuilt long block. I pulled the cap off of the distributor and there seems to be quite alot of play in the mechanism. What type and how much play are you talking about 4jaw? There is also alot of dust all over the advance mechanism(red). I know some is normal and it doesn't seem to make anything stick, but it does seem to be pretty sloppy. Can you be a little more specific 4jaw?
  #20 (permalink)
Old 08-13-2002, 08:40 PM
4 Jaw Chuck's Avatar
Post
Check your e-mail 71.
— Han Solo
  #21 (permalink)
Old 08-14-2002, 05:28 PM
66chevy2ss's Avatar
Post
Lloyd Topping and 4 Jaw:
I stuck a vacuum pump on the hose leading to the distributor, and was able to pull a vacuum. It held the vacuum as well.
The vacuum advance linkages did move, though I couldn't see exactly what they did (I didn't take the distributor and roter completely off, I just lifted the cap up).
But the linkages sort of "clicked", twice, as I was pumping vacuum (as if they held, and then moved quickly). Could it be that the mechanism is sticky?
  #22 (permalink)
Old 08-14-2002, 05:29 PM
66chevy2ss's Avatar
Post
By the way, the reason I'm so interested in this is that the guy I bought the car from suggested that there was something wrong with the vacuum advance.
  #23 (permalink)
Old 08-14-2002, 08:41 PM
Post
Sounds like time for a new distributor. Especially since you told me the shaft moves.
— Han Solo
  #24 (permalink)
Old 08-15-2002, 04:13 AM
66chevy2ss's Avatar
Post
But isn't the shaft supposed to move?
  #25 (permalink)
Old 08-15-2002, 05:16 PM
66chevy2ss's Avatar
Post
Something was moving in there, I'm not sure if it was the shaft.
At any rate, it made a suspicious "click" sound, twice, as if it was sticking. I have no idea...
Thanks for the help.
  #26 (permalink)
Old 08-15-2002, 06:38 PM
Post
Whoa, let me explain a little better.
The shaft is what rotates in the distributor and is how the rotor can deliver spark to each plug wire attached to the cap.
This shaft is driven by a gear off the camshaft and turns half crankshaft speed. The point/pickup are below the rotor and are the mechanism that lets voltage flow to the coil and also interrupts it (spark!).
The coil is a short term storage device that also happens to step up the voltage of the power coming from your battery, when power is flowing to the coil there is no spark-you need the rotor to be aligned for the power to have a place to go.
When the rotor is correctly aligned power will flow through the coil to the rotor conductor only when the pickup or breaker opens-interrupting current (power) flow to the coil. You can think of it as a dump truck filling (coil) and when the time is right the pickup/breaker trips the dump mechanism and the power will pour through the rotor to the cap-to your plugs wires and ultimately to your plug.
As you can see timing is everything and if there are any worn components such as a shaft that has freeplay it will change the time when the dump occurs, usually not in the same way each time. When this happens it is called spark scatter and means each cylinder will have a differently timed spark event with each revolution. This is not good.
Distributor shafts should have zero play in their bearings but the reality is most factory style distributors run in plain bearings (aluminum bore). As you can imagine these aluminum bores wear and when they do they develop clearance between the shaft and the bore (freeplay). Any freeplay will cause scatter to a certain degree. Worn advance components will also move the timing around by not being smooth in their movement or just binding and not advancing at all.
That click you hear is likely the mechanical advance or vacuum advance mechanism not moving smoothly, obviously it's worn. The red powder is another indicator.
Although their may be other factors contributing to your problem you cannot rule out the timing because you know the distributor is worn and is not functioning it's best. This is important enough that when I rebuild a motor there are a few things I replace right off the hop;
Distributor, fuel pump, water pump, oil pump and drive shaft, pushrods, rockers, lifters. These are all as important as each other and all are high wear/high stress components that are critical to the life of the engine in some way.
So what I am saying is you have found one problem, fix it. If is the only problem we can give high fives and go and race. If not then we look for the next problem and solve that one too, beer can wait. You can't solve your problem without fixing a possible contributor when you know it is bad. Hopefully it is the only one but likely it's not.
What this is called is HotRodding 101 and the lesson is "if it's broke, fix it!" The payback is certainly worth it. Let us know how it works out, diagnosing problems over the internet is hard enough without knowing if you ever got the problem solved. See you soon.
— Han Solo
  #27 (permalink)
Old 08-15-2002, 11:11 PM
Post
my 2 cents worth:
The distributor shaft should turn, but not move sideways. I just repaired my 69 Cougar's dist with this prob since with points any sideway play will throw the point's gap out to lunch. It also affects later non-point dists as timing advance may have to comensate for the play. If it's really bad the star can actually hit the pickup coil causing irradic or non-funtioning spark.
  #28 (permalink)
Old 08-16-2002, 04:23 AM
66chevy2ss's Avatar
Post
Thanks for the excellent replies. I guess I'll go and bite the bullet!
  #29 (permalink)
Old 08-16-2002, 05:41 AM
66chevy2ss's Avatar
Post
Jeez, here I go again! Thanks for your patience.
Could it be that (in my ignorance) I applied so much pressure on that hand pump that the vacuum advance mechanism went to its fullest potential, and then clicked back to its starting place? (therefore accounting for the "click" noise)?
If this was the case, perhaps this part isn't faulty.
  #30 (permalink)
Old 04-28-2010, 06:45 PM
u may even be off a tooth. i had the same problem with my six cylinder in my chevy pickup when i first rebuilt it. be fore the rebuild i had all the lifters frozen. changed everything ou. and it ran like a top for about 30 seconds. and then it ran like poo from then on i tried everything. it may hae been a blown bridge on the head gasket too
