Detrmine which Holley I have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 10:08 AM
I have a Holly spread bore mechanical secondaries on a SBC How can I tell what it is?I,ve taken some # of the base and body but don,t know it that will help.I,ts not a double pumper.6R4237B 12R-5395B
Old 12-28-2008, 11:01 AM
1952_Chevy_Panel's Avatar
Money pit
How about a number on the choke horn?
Old 12-28-2008, 12:11 PM
It may be an "economaster". I think that they were the only non double pumpers with mechanical secondaries. They are a small 450 cfm quadrajet replacement that look more like a quad than a classic holley and are supposed to be great for mileage. Does that sound like what youve got?
Old 12-28-2008, 07:20 PM
Re holley
I,d be surprized if its a 450cfm It looks big like a most Holleys as I know them.But I,ve been out of it for a while.Its large has two bowl and metering block .front and back.One fuel inlet in the front
Old 12-28-2008, 07:29 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Square bore right? measure the distance between adjacent bores and I can tell you.
Old 12-28-2008, 07:32 PM
Chock Horn
I looked on the chock horn found LIST 6210-3 1318 mean anything to anybody?
Old 12-28-2008, 07:58 PM
4165, 650 cfm
Old 12-28-2008, 08:03 PM
Spread bore
I looked down the carb the secondaries are much larger than the primaries ,that makes it a spread bore?Also when I open the thottle all the way While not running the secaries open and fuel is squirted from the rear into the secondaries makes it a double pumper? The # googled out to be 650cfm? I think seems like ther is mixed opinoin on these carbs.Thanks for your help like I said Ive been a tech in a dealership for 20 plus years but been 20 plus scince I tinkered.
Old 12-28-2008, 10:43 PM
JeffB's Avatar
Spread-bore Holley
I have used them in the past and liked them,they work best on intakes that are made for Quadrajet style Carbs,I am not a big fan of adapters to use wth them recently these carbs have fallen out of favor,I have a clean one for sale with a new Trickit,no takers in 3 months and it was priced LOW.
Old 12-29-2008, 11:20 AM
That would be a double pumper. They are a bolt on replacement for the q-jet and are supposed to outperform them in many ways, I doubt if they would match a q-jet for mileage though. Lots of good reviews on the webb about them, the jets and power valves are the same as other holleys but all else is different.
Old 12-29-2008, 11:49 AM
JeffB's Avatar
Spread-bore Holley
Some of them are also single pumpers,also Dodge used them in some of the motor home chassis.The single pumpers with vacuum secondaries are more fuel friendly and easier to tune than Quadrajets.
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 09:35 AM
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
Holley throttle body Kevin45 Engine 1 06-10-2005 11:46 AM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
