detroit locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 09:38 PM
jgh64pkup's Avatar
Last journal entry: new et streets
detroit locker
does anyone have pics of a detroit locker such as looking in the case and the case itself
Old 03-25-2009, 09:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
here try this.hope it helps.http://images.google.com/images?hl=e...num=1&ct=title . cole
Old 03-25-2009, 10:03 PM
jgh64pkup's Avatar
thanks for your time i think i got one of those gov-lock things i saw on here earlier but it was free and it works so i cant complain
Old 03-25-2009, 10:25 PM
ericnova72's Avatar
More for Less Racer
You will complain when it blows up, and it will. Well known fact that anything more than a bone stock vehicle will break one of these pretty easily. Heck, a stock truck with nothing more than 33" tires is a risk. I've seen several after the fact, and it usually ruins everything, including the housing.
Just a little friendly info.
Old 03-25-2009, 10:34 PM
jgh64pkup's Avatar
ive got a mild 350 somewhere around 400 ft lbs of torque i havnt broken it yet i have 28 inch mt et street radials
im not entirerly sure its a gov lock but from pictures it looks very similar
when i got it i was told it was a detroit locker
Old 03-25-2009, 10:47 PM
ericnova72's Avatar
More for Less Racer
If it is a Gov-Loc, the key word in your sentence is YET.
If you can afford to replace the rear easily because you've got spare parts or a friendly wrecking yard nearby, then I'll agree, run it till it blows. Just realize that it is the weakest traction differential built.
The real Detroit Locker is a whole different animal.
Old 03-26-2009, 10:42 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Im dropping the carrier out of my 9" tonight after work, has a true Detroit Locker, I'll take a picture of it before I disassemble it.
Semper Fi
Old 03-26-2009, 11:35 AM
jgh64pkup's Avatar
thanks how are spools on the street
Old 03-26-2009, 11:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The DL isn't a spool, it will lock and unlock in a turn. The older models were notoriously noisy clicking and popping as they engaged and disengaged. They can be touchy in rain, not as drastic as a true spool, which is a solid link, no differential action.
The newest Detroits are very quiet, the SofLok, I don't believe they even sell the old clickers any longer. There are many options out there, I prefer the Detroit Locker due to their strength and internal structure, along with a good track record.
Semper Fi
Old 03-26-2009, 12:47 PM
SSedan64's Avatar
5 Pages of Diff Pics here.>> http://rides.webshots.com/album/55410292AnMJrE
Old 03-26-2009, 01:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I can't access that site from my DoD work computer, but does that mean I don't have to pull mine out for pictures, lol? No. Need to change the R&P, which means dropping the entire rear suspension to get the tires/axles out.
My guess is SSedan gave you exactly what you need. I'll take a picture of mine for grins though.
Semper Fi
Old 03-26-2009, 02:44 PM
jgh64pkup's Avatar
well that sucks
i know a detroit locker is not a spool but they are a lot cheaper
i was wondering how good a spool worked on the street
i also cant find a detroit locker for my application
1972 12 bolt chevy truck 30 spline
Old 03-26-2009, 02:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Spools are just not for the street on a daily driver. Neither are welded spiders. Same thing, acts like a "live" axle, no diff action.
There should be a DL for your app, I will look later if you've not found one by then.
Old 03-26-2009, 03:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
None of these? Looks like they cover every 12 bolt out there.
http://www.jegs.com/webapp/wcs/store...2Bmatchpartial
Semper Fi
Old 03-26-2009, 04:08 PM
SSedan64's Avatar
Detroit Locker.>
http://www.ringpinion.com/PartsList....b-Differential
http://www.ringpinion.com/DiffDetail...ame%3dGM%2b12T
http://www.ringpinion.com/PartCats.a...fName=GM%2012T
Is a Detroit locker streetable? jimrinob Transmission - Rearend 8 06-04-2006 06:08 PM
Detroit locker vs. Posi vs. Spool juiced66malibu Transmission - Rearend 7 04-14-2006 11:04 AM
Detroit Locker henny496 Transmission - Rearend 8 11-06-2005 09:34 PM
detroit locker??? fireforsin Transmission - Rearend 5 01-29-2004 10:00 PM
Detroit Locker I.D. 68NovaSS Transmission - Rearend 0 09-21-2002 04:00 PM
