detroit locker??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2004, 04:09 PM
fireforsin's Avatar
Novaaaa
detroit locker???
i am looking for a detroit locker for a chevy 10 bolt 8.5" new or used. I tried ebay and summit but cant seem to find one for this set up. can anyone point me to a place that has them or maybe someone would sell me one?
thanks,
mike
Old 01-29-2004, 07:57 PM
68NovaSS's Avatar
Wiki Edits: 9
They have them here, a little pricey but you'll only buy once!
Go to shop by department, then drivetrain/hard parts and you'll find it. The Soft Lock is their brute, they don't make the noisey lockers, this is the same industrial strength unit but much quieter. I don't believe you can even buy the old DL any more.
http://www.macromotive.com/shopping/....147.2631.8818
Old 01-29-2004, 08:13 PM
fireforsin's Avatar
Novaaaa
well thanks, another question. i see all these lockers but they say for GMC and Suburbans. would these fit my 73 nova with a 10bolt 8.5?
thanks,
mike
Old 01-29-2004, 08:37 PM
68NovaSS's Avatar
Wiki Edits: 9
Should, as long as you get the correct series for your ratio and spline - you should ask about the axle diameter though. The guys there are really good guys and will give you all the info you need when you talk to them.
Old 01-29-2004, 08:49 PM
fireforsin's Avatar
Novaaaa
do you know of an easy way to check how many splines are on your axle? like just taking off the diff. cover, or is the only way to take the axles out?
thanks,
mike
Old 01-29-2004, 09:00 PM
68NovaSS's Avatar
Wiki Edits: 9
Unless you can find the codes and specs for your particular car you'll have to pull the axles. Not a big deal but time consuming, remove the wheel, brake drum and shoes. Take the cover off, rap the axle inward until you can get at the C clip with a pencil magnet and pull it out (it's a loose fit), then slide the axle out. You may have to pry it an inch or so to get it moving.
When you put it back in, push it all the way in, install the C clip and make sure you pry it back to the outside to make it move inside the shrouded area that will keep it from falling off. That's pretty simplified but easy to do.
